» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W124 E,CE,D,TD Class
Old 10-04-2008, 11:25 AM   #1 (permalink)
Date registered: Sep 2008
What can you learn for an MB VIN #?
Hi everyone,
Is there a MB data base that lists info about the cars based upon the VIN # of the car? How about carfax? Does anyone have an account for that service? I would like to find out what data exists on the possible "free" 92 400E.
The VIN is: WDBEA34E9NB804902
Thanks,
Zack
Zack1978 is offline   Reply With Quote
Old 10-04-2008, 11:31 AM   #2 (permalink)
augapfel's Avatar
Date registered: Jan 2006
Vehicle: 88 260E, 88 300TE x 2, 88 300E x2 (parts), 90 300TE 4Matic (parts)
If you go to the russian VIN decoder site and enter the VIN you'll get a lot of info about the car as it was originally built. Engine type and serial number, trans type and serial number, order date, paint and upholstery colors, and options/equipment installed.
Mercedes-Benz Club Russia | Mercedes-Benz / VIN
augapfel is offline   Reply With Quote
Old 10-04-2008, 12:07 PM   #3 (permalink)
MBeige's Avatar
Date registered: Jan 2004
Vehicle: 83 300D, 89 190E, 90 300TE, 93 190E
So much to learn
VIN WDBEA34E9NB804902
Model 420 E
Chassis 1240341B804902
Engine 119975 12 004894
Transmission 722354 03 737505
Order 0 2 704 05670
Approx. year not defined
Dealer United States (USA) (704)
Interior leather grey / orion gray (268)
Paint
147 arctic white (T) (с 01.01.1985 по 31.12.1993)
68 Unknown code
240 outside temperature indicator (с 01.03.1982)
second spare wheel (с 01.01.1964 по 28.02.1973)
241 left front seat electrically adjustable with memory feature. only applicable to w 210 when installed in conjunction with code 275. (с 01.03.1983)
wood rims (с 01.01.1964 по 31.08.1971)
280 trunk set, 3-piece (с 01.09.1964 по 31.08.1972)
steering wheel (400 mm dia.) and gearshift lever in leather trim; on W202 390 mm dia. (с 01.05.1984)
291 airbag for front passenger
airbag for front passenger (с 01.10.1993)
airbag for driver and front passenger (с 01.07.1987 по 30.09.1993)
airbag for driver and front passenger (if driver airbag standard - then only for passenger)
garment trunk, large (с 01.02.1967 по 31.05.1973)
trunk set, 7-piece (с 01.01.1976 по 31.08.1978)
300 storage box in front tray (с 01.05.1988)
taxi design without compartment wall, taximeter instrument panel (с 01.01.1968 по 31.07.1968)
340 additional 3rd stop lamp (с 01.10.1989)
front seat, right, lower (с 01.03.1967 по 28.02.1986)
412 electric sliding roof with tilting device (с 01.07.1983)
hydraulic sliding roof, in the rear (с 01.11.1964 по 30.06.1981)
430 headrests in the rear (с 01.01.1977)
safety belts, front and rear (с 01.01.1964 по 31.05.1973)
441 steering column, electrically adjustable, W202 manually adjustable (с 01.07.1984)
bumper, front, with guards (USA version) (с 01.01.1963 по 30.09.1970)
461 instrument with mileage reading and english lettering (с 01.04.1990)
471 acceleration skid control (ASR) (с 01.07.1984)
special export version for bad road conditions and oil bath air cleaner on export vehicles (с 01.01.1963 по 31.01.1968)
oil bath air cleaner for export vehicles (с 01.02.1968 по 31.12.1976)
491 USA version (с 01.01.1963)
524 Reims adapter IV (с 01.04.1962 по 28.02.1963)
paintcoat preservation (с 01.01.1964)
543 exhaust-pipe cover trim (с 01.01.1963 по 28.02.1963)
seat adapter between the front seats, and halogen lamp unit (с 01.01.1967 по 31.12.1972)
sun visor with vanity mirror, illuminated, left and right (с 01.11.1978)
551 anti-theft warning system (с 01.11.1978 по 31.03.1998)
anti-theft/anti-break-in warning system with anti-towing system (с 01.04.1998)
steering wheel, ivory-colored (с 01.01.1963 по 31.05.1973)
570 folding armrest front w202/210 stowage box front with armrest (с 01.04.1970)
front folding armrest w202 - housing at front with armrest
588 Thermoking air conditioner and electric window lifters (front doors) (с 01.04.1970 по 31.12.1972)
automatic climate control and electric window lifters (front and rear doors) (с 01.01.1977)
593 headlamp flasher and turn signal lamps - italy (с 01.01.1963 по 31.07.1965)
headlamp flasher and turn signal lamps, front, crystal clear (с 01.08.1965 по 31.01.1967)
heat-insulating glass, rear window pane (с 01.02.1967 по 31.01.1971)
heat-insulating glass, all-around, heated rear window pane (single-sheet safety glass), band filter
green heat-insulating glass all round, heated rear window, single pane safety glass - tinted strip (с 01.01.1972)
600 headlamp wiper/washer (с 01.08.1971)
trim strips on hardtop (с 01.04.1963 по 31.07.1971)
611 courtesy lamps for front and rear doors, with W124 also for central doors/W202 front doors only (с 01.11.1978)
sealed beam lamp unit, l.h. traffic (с 01.01.1966 по 28.02.1972)
lamp unit, symmetrical (с 01.01.1962 по 28.02.1963)
639 radial-ply tires, elimination of warning triangle (с 01.11.1973 по 31.10.1974)
elimination of first-aid box and warning triangle (с 01.08.1977)
652 Dunlop tires (с 01.01.1963 по 31.07.1972)
8-hole light alloy rims (с 01.01.1990)
664 tires 275/55 r 17 with chromed light alloy rims (с 01.01.1995)
wood rims (с 01.01.1963 по 30.06.1964)
10 liters of fuel and mode of packing VE III (с 01.01.1979 по 30.06.1993)
731 wood trim, burred walnut root (с 01.08.1980)
757 Becker radio Grand Prix 2000 - USA (с 01.06.1990 по 31.03.1994)
radio with cassette (loudspeakers and antenna included) (с 22.05.1996 по 11.11.1996)
802 Change of year of model, last figure shows new model year
810 roof-mounted loudspeaker (с 01.11.1962 по 30.11.1972)
loudspeaker, sound package
sound package (bose) (с 01.12.1986)
MBeige is offline   Reply With Quote
When will they ever learn? ohlord W210 E-Class 7 09-19-2007 06:38 PM
How do you learn this? edfreeman Off-Topic 1 02-24-2007 08:04 AM
Want to learn more! rousch Unimog 3 02-22-2007 10:05 AM
Learn more about your W211 nguyensteve W211 E55 AMG, E63 AMG 2 05-25-2004 10:03 PM
learn from this mike smith R170 SLK Class 14 12-19-2003 06:45 AM
