400E/E420 - possible to remove smog pump? - Mercedes-Benz Forum
post #1 of 13 (permalink) Old 08-30-2008, 08:49 AM Thread Starter
zviratko's Avatar
Date registered: Jan 2007
Vehicle: W124 400E, W126 500SE
Hi,
is it possible to remove the smog pump from 400E/E420? I looked at the belts and it doesn't seem possible to "skip". I don't want to just disconnect it (it works), but the bearing is shot so I need to pull it out and reroute the belt some other way... but I found none :/
Has anybody done that?
zviratko is offline
post #2 of 13 (permalink) Old 08-30-2008, 09:03 AM
BAStumm's Avatar
Date registered: Oct 2006
Vehicle: 1990 300E 2.6
I removed the smog on my 300E and bought a shorter belt, search by author for posts by me.
BAStumm is offline
post #3 of 13 (permalink) Old 08-30-2008, 09:57 AM Thread Starter
zviratko's Avatar
Yeah, but the belt arrangement on 300E will be quite different (M103 x M119 engine). Shorter belt "only" doesn't work in my case...
zviratko is offline
post #4 of 13 (permalink) Old 08-30-2008, 08:51 PM
Date registered: Mar 2008
Vehicle: 2009 E350 4Matic
Looks like U got more luck with post only Bastumm answer my last one. I got the same problem 1994 E420 and I try to bypass mine too. What I noticed today my pump randomly start working when car is hot. Any ideas. It sound that is working during cold start ups but after I cancel it throw code after day or two. Maybe pump working for few seconds when engine is hot create a problem not damaged pump.I am lost Hopefully somebody can put some lights on our cases.
Burbur
burbur is offline
post #5 of 13 (permalink) Old 08-31-2008, 03:18 AM Thread Starter
zviratko's Avatar
I don't know how it is supposed to work in the US, but in EURO version the smog pump is supposed to only come on for a short time after a cold start - not permanently and not when the car is hot...
zviratko is offline
post #6 of 13 (permalink) Old 08-31-2008, 09:01 AM
BAStumm's Avatar
thats what mine did, on startup it ran for some time then stopped and freewheeled the pulley but in my case the bearing on the pulley went bad, the pump was still good. I couldn't find a way to fix just that bearing or pulley so I pulled the whole thing out. Do you have a diagram of the belt for your model? Maybe I could figure a way to remove it for you if I saw the belt routing.
BAStumm is offline
post #7 of 13 (permalink) Old 08-31-2008, 01:50 PM Thread Starter
zviratko's Avatar
BAStumm: none online... I'll try to look one up tomorrow
yeah that's just what it does on mine - pump is fine, clutch is fine, but the pulley bearing is shot...
zviratko is offline
post #8 of 13 (permalink) Old 08-31-2008, 01:59 PM Thread Starter
zviratko's Avatar
there's the v-belt routing, the smog pump should be the one on the left side of the picture - i can't think of a way to reroute it :/ maybe install just a pulley in the same place...
zviratko is offline
post #9 of 13 (permalink) Old 08-31-2008, 02:59 PM
BAStumm's Avatar
Farthest left and at middle elevation is your smog pump right? Below that is the alternator right? To the right of the smog pump is an idler pulley?
Dang that seems very similar to my car in the location of the items and route of the belt with the exception that the items to the left side are are at slightly different heights. On my car I was able to just remove the smog pump and use a shorter belt following the exact same route with the only exception of bypassing where the smog pump used to be. Have you compared this drawing to your car? Maybe it is not completely accurate in the height of items.
I also think it would be possible to repair the pulley by purchasing new bearings if a guy could figure out how to get the pulley off. I investigated shortly on mine and couldn't figure it out, course I didn't spend much time because I had already realized I could eliminate it and knew it would not affect emissions testing here locally.
BAStumm is offline
post #10 of 13 (permalink) Old 08-31-2008, 03:39 PM Thread Starter
zviratko's Avatar
I was told the bearing was highly atypical and only to be found in certain kinds of fridge compressors... not sure about this but I don't need smog pump anyway
It's hard to see anything on my car, but it looks quite accurate. I'll need to get radiators off to see exactly how it looks...
zviratko is offline
    Air Pump/Smog Pump? One in the Same? J Dubb W126 S,SE,SEC,SEL,SD,SDL Class 9 12-30-2016 09:58 PM
    400E smog pump bearing replacement? zviratko W124 E,CE,D,TD Class 0 07-14-2008 12:47 AM
    Ace'd the smog check, ultralow emissions 400E. Also, maybe for sale? walterrohrl W124 E,CE,D,TD Class 1 10-10-2007 08:34 PM
    92 400E Power steering pump and water pump, need advice kanio W124 E,CE,D,TD Class 5 03-19-2007 06:58 PM
    400E smog problems srydy General Mercedes-Benz 0 02-10-2004 01:21 PM
