Old 07-14-2008, 04:36 AM   #1 (permalink)
Date registered: Jul 2008
230te central locking
Hi, my 230te will unlock with the key in the drivers door , no problem. But it won't activate the other locks. The air driven actuator works fine and will unlock the other doors. The switch in the lock itself does switch and make a contact when I check it using a meter. The two wires feeding that switch do not seem to carry a current that can be switched to send a signal. Any ideas
230teehee is offline   Reply With Quote
central locking crasherroberts V-Class 1 01-11-2008 10:15 AM
Central Locking pump faulty - worth replacing or new locking motors? jpdp.au W210 E-Class 2 11-26-2007 03:03 PM
Central Locking IRLAM R129 SL Class 1 03-01-2007 03:31 PM
central locking dc98354 R129 SL Class 6 08-25-2005 05:28 AM
Central locking??? Guest (MBNZ) W201 190E, D-Class 3 06-20-2002 05:59 AM
