Old 07-03-2008, 10:58 AM   #1 (permalink)
Date registered: Apr 2007
Vehicle: 1989 300 TE 4-Matic
Harsh shifting only when warm
my 300TE-4Matic shifts perfectly smooth when cold and part warm.
Now that is gets unusually warm (above 35°c), the shifting gets progressively more harsh as air (and gearbox) temperature increases.
I checked the vacuum lines and modulator, both are fine. I turned the modulator 2 clicks with no result. Oil has 15K miles in the box. Level seems OK (very hard to check, the level is more of a streak than a nice level on the dipstick).
I am about positive that the oil is he culprit, not tolerating the higher heat.
Anyone agrees/disagrees?
GeorgeK is offline   Reply With Quote
Old 07-03-2008, 01:52 PM   #2 (permalink)
MiguelXJ's Avatar
Vehicle: '91 230CE; '93 220E Sportline
How are you checking the level?
1991 230CE
1993 220E Sportline
1989 200TD - sold
MiguelXJ is offline   Reply With Quote
Old 07-03-2008, 09:44 PM   #3 (permalink)
Engine warn, running in neutral, on a flat surface after idling a few minutes. Markers on the stick oriented to the back of the car.
Old 07-03-2008, 10:29 PM   #4 (permalink)
zviratko's Avatar
Date registered: Jan 2007
Vehicle: W124 400E
Send a message via ICQ to zviratko Send a message via Skype™ to zviratko
I just had exactly the same problem including being unable to read from the dipstick... But I'm getting slipping 2nd->3rd at random, or harsh shifting at random.... Oil has 2000 kms on it - maybe something got flushed out...
zviratko is offline   Reply With Quote
Old 07-03-2008, 10:30 PM   #5 (permalink)
zviratko's Avatar
Vehicle: W124 400E
GeorgeK: you should read the level after either a ride or after shifting to all posititions a few times... PRNDNRNDNRND...
Old 07-04-2008, 04:02 PM   #6 (permalink)
MiguelXJ's Avatar
Gear lever should be in Park and engine tempo should be normal operating temp (aka 80-85ºC)
Check it that way and let us know.
Old 07-04-2008, 11:33 PM   #7 (permalink)
I will have the oil changed on monday, so we'll see if it solves things.
Old 07-04-2008, 11:37 PM   #8 (permalink)
I will change the oil on Monday, we'll see if it sloves the problem.
Old 07-09-2008, 09:54 PM   #9 (permalink)
Update:
We changed the oil and filter in the gearbox yesterday evening. The filter element was partly torn from its cartridge and partly sucked into he gearbox, thereby impeding flow out of the filter.
We got 4 liters out of the box and could put only 4 liters in, even thought the manual says 6.2 liters. It registers full on the dipstick, that now works as it should.
Is it all the trouble there was ? I don't know, but it is reassuring that something was not right.
Old 07-10-2008, 01:12 AM   #10 (permalink)
augapfel's Avatar
Date registered: Jan 2006
Vehicle: 88 260E, 88 300E x 2, 88 300TE x 2
To remove the most old fluid you have to drain the torque converter. There's a removable plug on the back side of the converter that you unscrew and fluid gushes out. A lot!
Have you made any progress on your cam/rockers problem?
augapfel is online now   Reply With Quote
'83 300SD harsh shifting auto trans Redwomack W126 S,SE,SEC,SEL,SD,SDL Class 7 06-22-2008 03:17 PM
Harsh shifting 1983 500SL COLLIN380 R/C107 SL/SLC Class 2 04-16-2007 10:49 AM
Harsh shifting tranny on 1983 500SL COLLIN380 R/C107 SL/SLC Class 0 04-14-2007 08:04 PM
Harsh shifting when cold old soldier R170 SLK Class 8 11-28-2006 04:19 PM
transmission kluncking & harsh shifting repair done Umar Shafiq W163 M-Class 4 07-31-2002 12:22 PM
