Old 07-01-2008, 08:41 PM   #1 (permalink)
Date registered: Apr 2008
Vehicle: 1993 Mercedes Benz 300E 3.2 L
intermittent electrical problem
For 2 or 3 days my 1993 300E 3.2 mercedes will run fine, run like a dream
For 2 or 3 days afterwords the car will not start!
I checked and/or replaced:
Fuel pump
fuel relay
green fuel relay
gas cap
spark plugs
spark wires
battery
fuel pressure regulator
fuel filter
fuel lines (they did have gunk in them, but not no more)
misc routine maintence
any suggestions?
Ko-Ko-Klown is offline   Reply With Quote
Old 07-02-2008, 05:09 AM   #2 (permalink)
Sergio's Avatar
Date registered: Sep 2002
Vehicle: 1995 E320
When you say "it won't start" what are the symptoms? Do you hear the starter cranking and the engine does not turn on or is it completely dead? (No starter action)
Sergio
'95 E320 SE
'99 ML430 (gone)
'01 E320 Wagon 4-Matic
'94 C280 (R.I.P)
Sergio is offline   Reply With Quote
Old 07-02-2008, 05:42 AM   #3 (permalink)
RBYCC's Avatar
Date registered: May 2005
Vehicle: 88-300CE TWIN TURBO, 99-C43, 03-G55, 71-280SL, 94-E320 CAB
Fuel pump
fuel relay
green fuel relay
gas cap
spark plugs
spark wires
battery
fuel filter
any suggestions?
Has the main engine compartment wiring harness ever been replaced ?
The original harnesses were problematic with the insulation of the individual wires breaking down under the overall wrap causing intermittent and sometimes fatal conditions.
Expensive repair...$1500.00 +++
TURBOTECHNICS
M103 TWIN TURBO
RBYCC is offline   Reply With Quote
Old 07-02-2008, 08:22 AM   #4 (permalink)
macdrone's Avatar
Date registered: Nov 2006
Vehicle: 1993 400E 209000 miles
Ya I would check the wiring harness. But did you do a full tune up ever? The only time my MB wouldnt start (and I have had alot of issues with it) was when the coils went bad along with coil wires, and I don meen the only time it wouldnt start.
More discription would help tho.
macdrone is offline   Reply With Quote
Old 07-02-2008, 12:40 PM   #5 (permalink)
It cranks over fine. The starter works.
I dont know if it matters but, it only starts in cooler temps, such as nightime.
In the afternoon, no start what so ever.
Intermittent Electrical Issue- W220 JonnyBlayz W220 S-Class 13 05-27-2008 09:17 PM
4 matic intermittent problem jackrabbit W124 E,CE,D,TD Class 3 01-03-2008 06:28 AM
98 E320 Intermittent Electrical Problem from Center Console Farm Boy W210 E50 AMG, E55 AMG 2 02-20-2006 02:13 PM
Intermittent Idle Problem Pistolero63 R129 SL Class 1 12-15-2005 07:50 PM
Intermittent VES problem........ ed W163 M-Class 1 07-23-2005 10:22 AM
