Old 07-01-2008, 08:07 PM   #1 (permalink)
Date registered: Mar 2007
Vehicle: 1995 E320 Wagon
W124 '95 E320 wagon wipers constantly cycle
Anyone have ideas on the cure for wipers that cycle at will with the switch turned off. They will always be in delay mode when cycling at will and I have to twist the knob on then off and they will turn off for a while then cycle again over and over with no consistency. I had previously had turn signal problems and removed the multi-relay and cleaned all the contracts inside of it. The turn signals are now perfect but still have the wiper problem the same as before. I really think that the fusebox cover is warped and was putting pressure on the relay and causing some of the problems. I reinstalled the relay without its plastic cover and then installed the fuse box cover.
Anyone been here before, please chime in.....
speedt1 is offline   Reply With Quote
Old 07-02-2008, 09:25 AM   #2 (permalink)
Date registered: Jun 2007
Vehicle: '78 450SEL, '95 E320 T,'95 E300 DIESEL
Is it possible dirt or moisture got inside the turnsignal/wiper stalk?
Why is the fuse box cover warped? I'd most definitely replace it. Cheap, easy fix.
sbaert is offline   Reply With Quote
Old 07-02-2008, 11:52 AM   #3 (permalink)
Not sure "why" the cover is warped but it seems to be concave in nature....Before I cleaned the relay it would be fine in colder weather or in the mornings but when the temperature rose the turn signals/flasher would stop working and the wipers would start dancing at will.....It just seemed that the cover was putting pressure on the relay cover (really tight clearance) and when it was cooler the cover was fine but would warp/extend when the temperature rose....I purchased a brand new turn signal lever and it did not change anything..that was before I was informed about the multi relay..
Old 07-02-2008, 05:14 PM   #4 (permalink)
Since you've already done the turn signal stalk, I would cover all the bases by putting in a brand new wiper relay and finish things up with a new fuse box cover.
Did any moisture/water or other contaminants (dust, sand, etc.) get inside the fusebox??? If so, I would remove all fuses and replace them as well. Take out all the relays, and dry each relay (a couple of minutes using the hair dryers carefully) as well as the bare fuse box with a hair dryer or equivalent. If crud got inside the box, suck it out with a shop vac or so.
wtb 1994-1995 w124 e320 wagon Prez808 For Sale, Trade & Wanted Items 0 07-28-2007 02:27 PM
W124 E320 wagon. 185k is it OK? Bansai W124 E,CE,D,TD Class 3 09-11-2006 09:01 AM
WTB - W124 300TE or E320 Wagon redsrover For Sale, Trade & Wanted Items 4 01-05-2006 07:23 PM
W124 Wagon (95 E320) iCruze Install drshaws Audio & Telematics Forum 0 11-21-2005 12:11 PM
Is there an easy way to turn the wipers on for one cycle only? Dany (Toronto) R170 SLK Class 4 09-10-2001 10:47 AM
