Old 07-01-2008, 09:19 AM   #1 (permalink)
Date registered: Jun 2008
how do I install new blower regulator
Can anyine advise me how to install a blower regulator to a 96 E320?
rftbx is offline   Reply With Quote
Old 07-01-2008, 04:48 PM   #2 (permalink)
Date registered: Jan 2008
Vehicle: 1993 190e-2.3; 1992 300E-3.0, 1998 Saab 9000T
First of all, why do you think it's a bad regulator? I just did this job on a 300e, which should be about the same, and I think it was a bad fuse. Just replace the big, 30 fuse under the 1/2 inch by 2 inch cover on the left fender in front of the fuse box. See what happens after that.
GPost is offline   Reply With Quote
Old 07-01-2008, 06:06 PM   #3 (permalink)
Date registered: Jul 2007
Vehicle: 1994 E320 Dragon Wagon
Yeah Bro, you need to detail how far you've troubleshot this. Could be a DOA motor or even a control unit issue.
1. Check the long 30A strip-fuse with a meter. Both sides should read hot to ground.
2. Disconnect regulator connector to the dash control unit. Test voltage measurements from control unit - low and high. Connector location and voltage readings can be found searching "blower motor" posts.
3. Dive down through the under-hood vent/plenum array of plastic 'till you reach the motor. Procedure is a bit nasty, including windshield wiper drive removal. Disconnect the motor connector and spin the motor applying direct power and ground. If the motor spins you're on the right track. If not, you need a motor.
4. Remove motor and you're looking at the solid state regulator mounted on a finned heat-sync directly below the motor mounting area.
Note: If any one of these items fail you will have a no blower condition. oops, this may be only good through '95, not sure about your '96 it may be another procedure.
Anything Made can be Made Better
White_Knuckles is offline   Reply With Quote
Old 07-02-2008, 08:35 AM   #4 (permalink)
macdrone's Avatar
Date registered: Nov 2006
Vehicle: 1993 400E 209000 miles
Whyte that was an excelent breakdown for sure. It doesnt get any better keep it up wow.
macdrone is offline   Reply With Quote
1998 W210 E300DT Bad Blower Regulator or Blower Motor?? How to tell DieselNuts W210 E-Class 4 08-30-2007 07:38 PM
Need a Blower regulator ????? Big"D"inTheMB W210 E-Class 0 07-19-2007 11:43 AM
Blower Regulator, where is it ??? Pancho W208 CLK Class 2 04-23-2007 08:03 PM
Blower Regulator pollyperkins13 W140 S-Class 3 11-28-2005 07:57 PM
1994 S500V W140 BLOWER AND BLOWER REGULATOR dbs600 W140 S-Class 3 07-08-2005 04:35 PM
