hi,i have a 230e that gives me hardstarting problems when car is warm or heated up,in the morning the cold start is fine, but when it is warm it takes 4 cranks to start up,after she starts she runs excellent,starting 3 or 4 times is embarassing.I replaced the fuel distributor with a rebuilt one and also replaced the fuel pump with a brand new one..But The Problem Still Occurs.Plese Help Anyone
Have you check the fuel pump relay?? I used to have the same problem, after i replace the fuel pump, accumulator & filter it still hard to start after warm condition, then i open the fuel relay(behind the battery console in engine bay) it get so hot(, i open it and spray the contact terminal with wd 40) it starts just fine that day ,but after 2-3 days , it began to stop starting even when it`s cold, so i open the relay plastic case and start to re-soldering the parts that seem to loose contact.........guess what, my engine starts normally till now(+/- 3 months now) I saved about Rp 700k(its approx 80$us parts in indonesia) for a simple DIY!
had this problem just a couple of months back.. simply replaced the fuel accumulator...
Mike
1975 200 - SOLD - now a hearse...
1978 200 - SOLD - now cannot be found...
1979 300TD SOLD - now has a new owner...
1985 230E - now my daily driver...
My 89 Mercedes Benz 300E is having a hrad starting problem as well. I have replaced OVP relay, Fuel Accumulator/Filter and check valves on each side, throttle body has been cleaned, and I recently got a full fuel injection cleaning. As far as hard staring, what else doI have left to do? Whether it's cold or hot outside, my car starts hard and gurgles for a few seconds until it can get it together, after it's minor seizuring it runs fine (so to speak) And what I mean by that is that there is a obvious miss, but it also has a stuck lifter so thats excusable. What do I do about this? Please help.
Also I wanted to ask what does the fuel pump relay look like and how do I disconnect it to check it out? Is it something that requires tools, and what should I be looking for if it is in fact bad. How much did it cost to Sauder it?
