Old 07-01-2008, 12:01 AM   #11 (permalink)
Date registered: May 2008
if you want faster "off the line" take offs, try moving the shift lever into the lowest setting while STOPPED, then back to D position before taking off. The transmission will start in 1st gear, not the usual 2nd gear start.
YMMV
sennasixty8 is offline   Reply With Quote
Old 07-01-2008, 03:14 AM   #12 (permalink)
zviratko's Avatar
Date registered: Jan 2007
Vehicle: W124 400E
Send a message via ICQ to zviratko Send a message via Skype™ to zviratko
I think a 2 litre engine is just too lazy for the car, you should have bought a 300E
zviratko is offline   Reply With Quote
Old 07-01-2008, 02:01 PM   #13 (permalink)
BenzLadin's Avatar
Date registered: Jun 2008
well the car wasnt like that always. It had a good take off. its still drives strong and has good power, but initial take off has retarded a bit. I dont know how to solve this.
AwesomA BenzLadin
BenzLadin is offline   Reply With Quote
1995 E200 using coolant Tephra W124 E,CE,D,TD Class 6 01-30-2008 03:16 AM
ECU reset acarter53 W210 E-Class 1 05-28-2007 08:43 PM
W124 1995 E320 Coupe factory security reset m6dtt General Mercedes-Benz 5 08-03-2006 09:07 AM
Learned driving habits salslk R170 SLK Class 1 11-19-2004 10:24 AM
ECU reset jtigr R170 SLK Class 4 06-05-2004 08:10 AM
