W124 Door handle removal. - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 06-21-2008, 07:13 PM Thread Starter
Date registered: Dec 2006
Vehicle: 1994 E320 sedan
Post W124 Door handle removal.
Hello, I'm hoping someone can give me some insight as to how the outer door handle comes off. I have removed the door panel,looked inside and see nothing that is a tell tale sign as to what to do. I am doing some paint work, and it needs to come off.
Any help would be greatly appreciated!!!!!!
Benz4both is offline
post #2 of 8 (permalink) Old 06-22-2008, 07:59 AM
MiguelXJ's Avatar
Vehicle: '91 230CE; '93 220E Sportline
On the door latch panel (not inside but on the door's outter part) you have 2 rubber grommets.
Remove the grommet that's leveled with the door handle and you'll see the bolt holding the door lock.
Cant remember what's left to do to remove the handle itself though...
1991 230CE
1993 220E Sportline
1989 200TD - sold
MiguelXJ is offline
post #3 of 8 (permalink) Old 06-22-2008, 08:42 AM Thread Starter
Hi, I removed the small plastic grommet, it looks like an allen screw that holds the lock cyl. There appears to be a screw showing through on the end of the handle closest to the front of the car. However, it is not visible from the outside. I am wondering if the outer chrome strip has to come off,and how that is done? I don't want to bend it or mar it up only to find out that now I need to replace a handle that I have no idea how to remove.
Thanks for your reply!!!!
Joe
post #4 of 8 (permalink) Old 06-22-2008, 05:31 PM
forcedawd's Avatar
Date registered: Aug 2003
Vehicle: 1997 S500, 2005 S500
Quoted: 19 Post(s)
Here you go -
forcedawd is offline
post #5 of 8 (permalink) Old 06-22-2008, 06:05 PM Thread Starter
THANK YOU! YOU ARE AWESOME!!!
So far this project has been turning out so much better than I thought it would, and at this point I hated the thought of just taping it off.
I've had it ready to shoot for 2 weeks now, but held back. Well worth the wait.
Thank you again!
Joe.
post #6 of 8 (permalink) Old 06-22-2008, 07:47 PM
forcedawd's Avatar
Quoted: 19 Post(s)
no problem, post some pics of the finished project.
post #7 of 8 (permalink) Old 06-22-2008, 08:44 PM Thread Starter
Sure will!
Joe
post #8 of 8 (permalink) Old 11-06-2016, 11:08 AM
Date registered: Apr 2016
Vehicle: 1987 300TD
Removing W124 front door handle w/o key
Originally Posted by forcedawd View Post
Here you go -
Thanks!
I repaired the damaged door on my '87 300TD by replacement with a door I removed from a car @ the Pick-N-Pull ... overall things went well, but I need to swap the lock from the old door so that I can use the key. I got the lock out of the original door using the procedure posed here ... THANKS AGAIN!
Since I can't actuate the lock, I can't seem to remove the lock from the new door. Is this something I need to have a locksmith do, or is it possible to get the door handle off without the key?
k1drbar is offline
    Door Handle removal? Cacciatore08 W201 190-Class 4 06-26-2008 05:26 AM
    Door handle removal? slanford77 W210 E-Class 1 04-14-2007 09:19 AM
    door handle removal jaguar4hb W124 E,CE,D,TD Class 0 07-26-2005 07:08 AM
    Door Handle Removal.... mrfu R170 SLK-Class 4 11-29-2004 11:03 AM
    Door handle removal rossocorsa W203 C-Class 1 09-30-2003 07:38 AM
