Old 06-21-2008, 03:00 PM   #1 (permalink)
Date registered: May 2008
A/C question on my 87 300TDT. I have searched quite a bit
So after much searching I found tons of posts about the climate control units. But I can't narrow down my problem.
Here's the deal: The A/C seems to work perfectly fine it just isn't blowing very cold air, even on the min. setting with the air set to recirculate. The temp of the air is certainly not the same as he outside temp (high 80's here in DC) but it isn't as cold as I think it should be.
Any ideas on what I should check out first?
Thanks
1987 300TDT - 192K - My first benz
pholway is offline   Reply With Quote
Old 06-21-2008, 04:44 PM   #2 (permalink)
Jayare's Avatar
Date registered: Jun 2005
Vehicle: 86 190E 2.3 16V, 90 300CE, 93 400E, 02 Olds Aurora
Unless your car has been converted to R134A, you need to go to an independant A/C shop and have the system checked out. R12 is still avaiable, but goes for about $60 per pound. You will be much better off taking the time and expense to have the original system service and checked out. Converting an R12 system properly, will cost you as much or more and won't cool nearly as well as the system was designed for R12.
Good Luck,
Jayare
Jayare is offline   Reply With Quote
Old 06-21-2008, 07:00 PM   #3 (permalink)
Good Luck,
Jayare
That's the plan. I found a well regarded indy Benz shop that specializes in W124s. Do you think it could just need a charge or some freon?
Old 06-21-2008, 09:06 PM   #4 (permalink)
augapfel's Avatar
Date registered: Jan 2006
Vehicle: 88 260E, 88 300E x 2, 88 300TE x 2
Yes, it could just be low on refrigerant. Look at the sight glass on the receiver-drier (which is located behind the left headlamp). When the engine is idling and the a/c compressor is operating the sight glass should be clear. Any bubbles going by the sight glass and a continuous flow of liquid refrigerant is not reaching the expansion valve. IOW the system is low on refrigerant.
augapfel is offline   Reply With Quote
Tachometer Question. (I have searched ;) Karl-Wilhelm W123 E,CE,D,CD,TD,TE Class 13 03-20-2008 10:21 AM
Simple DAS question and yes i searched already... StryknAccord W163 M-Class 0 09-13-2007 01:03 PM
searched but not much answer to headlight question msfamilia W203 C-Class 6 04-12-2007 11:41 AM
Fiberoptic question--I searched and searched to no avail!!! 01ML55 W163 M-Class 6 01-22-2007 12:33 PM
Where exactly is the AUX output in a 04' G500? I've searched and searched the forums Man-Du-Ru-Gas G-Class 11 12-28-2004 06:15 AM
