Old 06-17-2008, 01:58 PM   #1 (permalink)
Date registered: May 2008
Advise on Tires and Break Sensors
Got 16 SLK wheels. Installed with used Continental Conti's. Noisy so had it checked. One tire needs to be changed so changing two.
Goodyear
Americas Tire Co 216 installed for two new 16's (225)
Any other advise on tires. I am looking for soft ride and Quite Ride.
ABS light comes on and off at times. Shop says change Sensors and do 60k service car has 64k. 1988 260e. 350 for 60k service.
Any advise welcomed
MackMan is offline   Reply With Quote
Old 06-18-2008, 06:03 AM   #2 (permalink)
Vehicle: 95 E320 Cabriolet
I don't see how brake wear sensors can affect the ABS. I think there's something wrong in the translation and that your mechanic recommended changing the wheel speed sensors. Changing wheel speed sensors would make a lot of sense. Or maybe the tone wheel (serrated wheel with teeth on the hub) needs to be cleaned, or maybe the pickup coil next to the tone wheel has some debris on it.
Have you tried reading the codes? I don't know if you can read for wheel sensor codes on your model.
This message written with 100% recycled electrons.
Kestas is offline   Reply With Quote
why with all this power do the tires not break loose? imosh R129 SL Class 20 01-31-2008 12:26 PM
Need some good tires that won't break the bank Brady W124 E,CE,D,TD Class 12 04-30-2007 01:24 PM
need advise on tires mjg99 W123 E,CE,D,CD,TD,TE Class 6 04-08-2007 01:49 AM
best tires please advise vdubpower W220 S-Class 16 07-12-2004 08:09 AM
Will it mess up any sensors by going oversize in tires? m500 W163 M-Class 2 04-15-2004 09:42 AM
