Old 06-07-2008, 06:08 AM   #1 (permalink)
Date registered: Apr 2008
radiator question
my radiator leaking at the overflow tube on my 92 300e. can i buy that part separate from the radiator and where?
totos1 is offline   Reply With Quote
Old 06-07-2008, 01:51 PM   #2 (permalink)
Jayare's Avatar
Date registered: Jun 2005
Vehicle: 86 190E 2.3 16V, 90 300CE, 93 400E, 02 Olds Aurora
Check closely to see if you have a bad tube or a crack where the tube attaches. It the attachment fitting is cracked, replace the radiator. If it's the hose, replace it.
Good Luck
Jayare
Jayare is online now   Reply With Quote
Old 06-07-2008, 03:22 PM   #3 (permalink)
macdrone's Avatar
Date registered: Nov 2006
Vehicle: 1993 400E 209000 miles
well a radiator was way expensive so I used JB weld on the fitting and I am good to go.
macdrone is offline   Reply With Quote
Old 06-09-2008, 04:44 PM   #4 (permalink)
i was able to order the overflow fitting at Performance Products® – Performance Parts and Accessories. for $3.75 ,i think it will salve my problem. thanks for all the help!
the website is very good!!! mercedes superstore,free catalog too
Radiator question! Steve Johnson R170 SLK Class 3 04-26-2007 09:20 PM
radiator question karugs W123 E,CE,D,CD,TD,TE Class 6 10-17-2004 09:01 PM
Radiator question bluduc W126 S,SE,SEC,SEL,SD,SDL Class 2 09-15-2004 11:53 AM
Radiator question magic W201 190E, D-Class 2 09-23-2002 06:50 PM
Radiator question ted G-Class 4 11-26-2001 04:27 PM
