Old 06-15-2008, 01:18 PM   #11 (permalink)
RBYCC's Avatar
Date registered: May 2005
Vehicle: 88-300CE TWIN TURBO, 99-C43, 03-G55, 71-280SL, 94-E320 CAB
Originally Posted by PUMPISH View Post
thanks guys!"
Today we was driving a little and its amazing how easy the engine spooling thisturbocharger. Its starts allready about 1800rpm
We tryed some launch control
Idag blev det lite provkörning
YouTube - Mercedes 300CE turbo First start and launch
Why is it breaking up as you are revving the engine ?
TURBOTECHNICS
M103 TWIN TURBO
RBYCC is offline   Reply With Quote
Old 06-15-2008, 03:27 PM   #12 (permalink)
appatula's Avatar
Date registered: Aug 2006
Vehicle: 1980* 280CE, 1999* C280, CURRENT 1986* 300E
Send a message via AIM to appatula
PUMPISH! Glad to see you resurface again. I tried to get in touch with you about some base .msq maps for a M103 3.0L. It would really help me out giving me a "starting point" to tune from with my megasquirt build. If you could email them to me that would be wonderful, either way let me know! The CE is great, your work is great, lets see some BOOST VIDS!!!
email:
(bbc309 @ gmail dot com)
The Babys
appatula is offline   Reply With Quote
Old 06-15-2008, 04:12 PM   #13 (permalink)
PUMPISH's Avatar
Date registered: Dec 2006
Send a message via MSN to PUMPISH
It is launch control. I was just testing it.
We put at 4000rpm to build up boost up to 0,5 bar from the start.
We have a button in the car so I can just push and hold the button and getting launch control and I can choose RPM and the boost I want from the start. We tryed and it feels best att 4000rpm and 0,5bar boost to start with without loosing the grip.
By setting a lower rpm and back up the ignition about 20 degree and getting extra fuel I can choose the boost.
Great stuff for streetrace
I use antilag control with my onther car with manual tranny so I can make the same thing to keep the boost when i am changing gears.
But it is not good stuff to use too often
300E Turbo Megasquirt 650Hp/780Nm
190E 3,0 megasquirt
Band:
www.burlak.net
TURBOCHARGE YOUR MERCEDES
www.turbobandit.com
PUMPISH is offline   Reply With Quote
Old 06-15-2008, 04:15 PM   #14 (permalink)
PUMPISH's Avatar
email:
Thanks man!
Do you need turbomaps or npn turbo maps?
You know that every engine is individueal so it is no garanti that it will work on your engine. I use to tune every car even if it has the same engine.
But I can check if I have some ground map for you!
Old 06-16-2008, 01:54 PM   #15 (permalink)
Date registered: Dec 2004
Vehicle: 400E, 500E, 560SEC, C240
Awesome pictures! what a treat. good luck and keep us informed on any reliability issues or lack thereof that may or may not arise. What are premium petrol prices in Sweden. CA, USA about $4.75 avg.
Redwood
400E 4.2
500E 5.0
560SEC 5.5
C240 2.6
redwood is offline   Reply With Quote
Old 08-04-2008, 10:37 AM   #16 (permalink)
appatula's Avatar
non-turbo ground maps for the CIS-E M103 would be a great help!!! Turbo will come later
you can email them if that's easiest for you
bbc309@gmail.com
Just another turbo project california jay W201 190E, D-Class 44 11-09-2008 11:08 PM
1988 300CE M103 Twin Turbo Project RBYCC W124 E,CE,D,TD Class 30 03-22-2008 08:06 PM
300E Turbo project PUMPISH W124 E,CE,D,TD Class 61 01-27-2008 03:59 PM
w124 turbo project gR8jBenZ W124 E,CE,D,TD Class 1 03-07-2004 04:33 PM
300CE Twin Turbo Project Guest (MBNZ) W124 E,CE,D,TD Class 1 08-03-2000 11:13 AM
