Old 06-05-2008, 08:18 PM   #1 (permalink)
HighRoller's Avatar
Date registered: Nov 2006
Vehicle: Mercedes Benz E320
Question Wheels will fit or Not??
This wheels are in a basic 190E, they will fit a W124 or not?
18x8 front = ET35.
18x9 rear = ET 38. the vendor claim they will fit, but people here in the forum say they will not fit!!!! The 190E and 1994 E320 have the same ET fitment? Thanksoe-benz-car-162-f-s-33fps.jpg
HighRoller is offline   Reply With Quote
Old 06-06-2008, 06:09 AM   #2 (permalink)
hamada128's Avatar
Date registered: Jan 2007
Vehicle: 93 190E 2.3
If they were fitted in a W201 190E, then for SURE they will fit the W124.
1972 Fiat 128 1100cc
1993 MB 190E 2.3 255K
2008 Lancer 1300cc - Gulf Edition
MB Driver since 10/22/06
hamada128 is offline   Reply With Quote
Old 06-06-2008, 04:55 PM   #3 (permalink)
HighRoller's Avatar
I know!!! but some people in the forum state ,you cant fit 18x9 in the back of a w124the other pics are in the MBWorld forum (190E)Pics area.This guy just roll fenders. good to go.
Old 06-06-2008, 05:52 PM   #4 (permalink)
Date registered: Oct 2002
Vehicle: Mercedes 500E & CLK32K
The higher offset moves the wheel inward, with the lips rolled and the extreme negative camber, coupled with overly small, stretched tires, you might get away with minimal rubbing, assuming you don't have anyone in the backseat.
If rubbing of the wheel on the inner fender, bumper lip and/or upper part of the fender is not a concern to you, then you should be able to fit these. As you know others have fit overly wide wheels on their W124's so it is doable, but these are people not concerned with ride quality, tire wear, rubbing or transporting passengers.
Your call, the wheels do look good though.
1993 500E & 2000 CLK32K
2phast is offline   Reply With Quote
Old 06-08-2008, 11:02 AM   #5 (permalink)
HighRoller's Avatar
The vendor claim the wheels wil fit ? By what you say the will not!!. The E300 and the E320 is the same space inside fenders, front and rear???Thanks for the HELP.
Old 06-09-2008, 01:51 PM   #6 (permalink)
jgajito's Avatar
Date registered: Dec 2006
Vehicle: 1994 E320 (W124) 4-Door Sedan
Send a message via MSN to jgajito
18x8 front = ET35.
What year W201? the answer is yes and maybe a no.
Other models that will fit, is a flared fender for an AMG/EVO/Cosworth 190E.
1992-93, and unless you roll the fenders and don't lower the car, they could fit as early as an '85. It will not fit a Sportline. A vendor told me the same thing once on 18 x 7.5 +35, the rear fenders rubbed, so I had to roll them. I also had a 1.75" spring drop kit. A bad mistake along with some tokico's(very weak shocks/struts and cheap). If you do have lowered springs, get some higher spring shims(pads).
Good Luck.
BTW, I have 18 x 9.5 ET +35 on W124.
Vehicle is not lowered, but on Bilstein HD's.
With 2 mods:
  1. Rolled Fenders
  2. Adjustable Cambers
"Droppin' a dime, my 2 cents is free, give the rest to Uncle Sam..."
1983 190E 2.3L 8V
(deceased, and sold on Ebay)
1994 E320 Sedan White & Grey
(Keeper)
RE: the 190E Evo II Rear Wing Spoiler.BMW research and development chief, Wolfgang Reitzle: The laws of aerodynamics must be different between Munich and Stuttgart...
IF THAT REAR WING WORKS, WE WILL HAVE TO REBUILD THE BMW TUNNEL... and so they did!!!
jgajito is offline   Reply With Quote
Old 06-09-2008, 07:18 PM   #7 (permalink)
HighRoller's Avatar
Good Luck.
With 2 mods:
  1. Rolled Fenders
The ET on this wheels are 38(rear) not 35 like yours and the car on this pic is not a 16v is just a plain w201 190E 2.6 but thanks anyway.
Wheels/Tires HELP-19x8.5 wheels w 245/35/19 - will they fit front of W210 4matic??? das_benz W210 E-Class 0 05-01-2008 09:41 AM
will s or cl 19 inch wheels fit on a 2001 c240 and if not can i make them fit and still look good? loweredbenz The Discount Tire Direct Tire, Wheel, Brake & Suspension 2 02-04-2003 05:15 AM
Will the lug bolts from standard 17" wheels fit the 18" AMG wheels??more RezaH R230 SL Class 1 10-26-2002 09:58 PM
Anyone know where the best deal is on ML55 wheels? What All season tires fit the 18" wheels?? JPinTO W163 M-Class 12 01-24-2002 11:02 PM
Will 10 in. wide wheels fit on the rear of an slk, how about 9.5 in. wide wheels, all 18 in. diam. Guest (MBNZ) The Discount Tire Direct Tire, Wheel, Brake & Suspension 0 10-30-2001 01:16 AM
