Old 05-21-2008, 08:10 AM   #1 (permalink)
Date registered: Feb 2008
92' 300D- low oil pressure a problem?
greetings all,
would like to solicit your opinion on a matter.
my 92 300D 2.5 Turbo seems to have low oil pressure. She has been idling around 1K, but as we use the a/c more, it barely rises above 0 at idling.
is this cause for concern? engine sounds fine, nothing abnormal in driving.
it of course gets up in the 2-3K range when accelerating or highway speeds.
thanks in advance,
raymond
rhlbenz is offline   Reply With Quote
Low oil pressure Denver W126 S,SE,SEC,SEL,SD,SDL Class 7 03-06-2008 10:22 AM
1984 sedan 300d - low oil pressure when warm and at idle lupi W123 E,CE,D,CD,TD,TE Class 7 02-09-2008 07:55 PM
Low oil pressure Raymond J General Mercedes-Benz 1 07-12-2006 10:25 AM
Low oil pressure. Problem andrew_falky W126 S,SE,SEC,SEL,SD,SDL Class 5 05-07-2006 05:25 AM
Low oil pressure at idle? Is this a comon problem? buckwyatt General Mercedes-Benz 5 10-26-2004 01:13 AM
