Old 05-18-2008, 12:04 PM   #11 (permalink)
Date registered: May 2008
Try to unplug the stuck fan and change the fuses, then check if the fuses blow again, if they dont it`s a good chance that the stuck fan is the reason it overheats and blows fuses.
If the oilpressure is .5 at idle I suggest you beat up the bastard sold you that engine, on my the oilpressure is at 2-2,5, but I live in Norway, maybe colder here than were you live. here we throw engines or fix them with pressure under 1-1,5.
oilpressure cold idle should be 2,5-3
W124.023
I`m from Norway and not so good at English
brEinar is offline   Reply With Quote
Old 05-20-2008, 05:45 PM   #12 (permalink)
floridabenzboi's Avatar
Date registered: Feb 2004
Send a message via AIM to floridabenzboi
Problem solved.
Replaced thrmostat with new and the fans were inop when trying to jump them. Ordering new ones.
B
floridabenzboi is offline   Reply With Quote
Restoring 89' 300E Opinions on Ideas torrem3 W124 E,CE,D,TD Class 2 06-26-2007 10:04 PM
battery overcharging overheating 87 300E vetan W124 E,CE,D,TD Class 2 03-07-2006 01:08 AM
300E W124 LONG BEACH/LOS ANGELES MEET?? ANYONE INTERESTED IN SHARING IDEAS? PROJECTS? YNVDIZW124 Events 0 04-21-2005 07:12 PM
1987 W124 300E hard to start hot or cold Any ideas. rcs hawaii W124 E,CE,D,TD Class 1 12-15-2004 08:31 AM
I've run out of ideas, does anyone have any new ideas on any SLK modifications? ImportTunerTyp R170 SLK Class 15 01-10-2003 12:20 PM
