Old 05-18-2008, 05:56 AM   #11 (permalink)
Date registered: Jul 2007
Vehicle: W124 E320 Coupé 1996, W124 300E twin turbo 1990, W126 300 SE 1991, Ford Capri 2.8i 1984
This is a US product:
RETRO PRO R12 TO R134A CONVERSION*::*Primalec Products*::*Autokool
RogerJones is offline   Reply With Quote
Old 05-18-2008, 09:12 AM   #12 (permalink)
GDC
Date registered: Mar 2006
Vehicle: 1994 E320, 1993 300E
Go ahead and do the conversion. If you have lived for some time with no AC, then the ~90% (vs R12) cooling you will get from 134 wiil seem like a godsend. Does your car currently have refrigerant in it? If so, you will have to have it removed and captured by a certified tech as you can't release refrigerant into the atmosphere. If there is no refrigerant left in the system you will want to pull a vacuum on the system to make sure you don't have any major leaks. You can do this yourself with a cheap set of AC gauges and a vacuum pump from Harbor Freight.
If you have small leaks, you might be able to get away with a sealer like Cliplight Super Seal Pro ( this stuff seals leaks in metal components as well as rubber and I am told it is used by MBUSA as an alternative to replacing evaporators). You will also probably want to replace the drier or at least heat the old one while it is under vacuum to remove any water that has accumulated in the dessicant over the years. I have converted several cars over the years, mostly American, but also an Audi and one Merc and I was not able to tell much of a difference between R12 and R134.
Good Luck
GDC is offline   Reply With Quote
Old 05-18-2008, 04:09 PM   #13 (permalink)
neanderthal's Avatar
Date registered: Dec 2003
i was able to get R12 (albeit not as cheaply) installed in my car a few years ago. last i talked to my mechanic he could still get it/ had it.
it subsequently got in an accident and had R134 installed.
'O=00=O' BMW 2002. long live the legend.
neanderthal is offline   Reply With Quote
Old 05-18-2008, 08:36 PM   #14 (permalink)
~BANNED~
Date registered: Sep 2007
Vehicle: 99 S420 (76k Mi) 90 300SE (87k Mi) 08 Lexus ES350 (7k Miles) 07 GMC Sierra (8k Miles) Sold list -->
Did you read anything on the first page? Yes, you can still get R12 (easily). And no, you don't have to get ripped off and buy it from a mechanic.
mr.xpowerseller is offline   Reply With Quote
Old 05-20-2008, 12:13 PM   #15 (permalink)
Vehicle: E300, 300CE, 300TE, 190D
Freeze 12
Freeze 12 is a mix of R134a and R142 (propane). One should not top off R12 with Freeze 12, i.e., mixing R12 with R134a. People do it anyway because it works short term.
95 E300, 93 300CE Cabriolet, 91 300TE, 84 190D
ds190 is offline   Reply With Quote
Wanted air conditioning compressor for 1988 300e davepasch For Sale, Trade & Wanted Items 1 10-16-2007 10:57 AM
87 300E Air conditioning problems felix31 W124 E,CE,D,TD Class 3 07-02-2007 03:10 PM
Recharging Air Con Jonathan Laws W126 S,SE,SEC,SEL,SD,SDL Class 30 04-02-2007 04:49 PM
1991 300E Air Conditioning..... giles117 W124 E,CE,D,TD Class 11 07-16-2006 06:02 AM
Freon Recharging lpaddikt General Mercedes-Benz 7 07-15-2005 01:44 AM
