Old 04-25-2008, 08:26 AM   #1 (permalink)
Jayare's Avatar
Date registered: Jun 2005
Vehicle: 86 190E 2.3 16V, 90 300CE, 93 400E, 02 Olds Aurora
Aux Fan Problem
Yesterday I noticed that my aux. fans were not coming on. One has always been "iffy", but the second worked perfectly. I've checked the fuse, changed the fuse and still nothing. One of the fans did "try" to run when I tapped it a few times, but since then nothing. I also pulled the sensor lead and jumped it. When I did that last night, the idle dropped, but no fan motion.
Is there a relay in the system I can check/change? I have spare relays for just about every thing. Thanks for the suggestions, tips.
Jayare
Jayare is offline   Reply With Quote
Old 04-25-2008, 09:49 AM   #2 (permalink)
Sergio's Avatar
Date registered: Sep 2002
Vehicle: 1995 E320
Yes, there are two relays under the fuse box module. One is for the low speed, the other for the high speed. If you jumper the AC pressure switch (larger diameter), the fans should come on LOW speed. If you jumper the AC temperature switch (red in my car), the fans should turn on HIGH speed. This way you can determine which relay, if any, is bad.
Sergio
'95 E320 SE
'99 ML430 (gone)
'01 E320 Wagon 4-Matic
'94 C280 (R.I.P)
Sergio is offline   Reply With Quote
Old 04-25-2008, 09:53 AM   #3 (permalink)
Jayare's Avatar
Thanks Sergio
Jayare
Old 04-26-2008, 11:58 AM   #4 (permalink)
macdrone's Avatar
Date registered: Nov 2006
Vehicle: 1993 400E 209000 miles
sensors
You can also jumper both switches before you mess with the relay to see if its the sensor.
macdrone is offline   Reply With Quote
Old 04-28-2008, 09:46 AM   #5 (permalink)
Date registered: Feb 2007
If you pull the 2 wire connection off of the thermostat gooseneck the fans should turn on at high speed. Nice easy check.
roycehof is offline   Reply With Quote
Aux fan problem mr.xpowerseller W126 S,SE,SEC,SEL,SD,SDL Class 15 03-03-2008 11:20 PM
Aux Fan problem GDC W124 E,CE,D,TD Class 1 10-16-2007 07:39 AM
Aux fan problem on my 87' mike 420 W124 E,CE,D,TD Class 0 12-30-2006 11:10 PM
Strange Aux Fan problem JemP W124 E,CE,D,TD Class 6 09-20-2006 01:53 AM
aux.fan problem oldcarpappy General Mercedes-Benz 3 02-08-2006 06:01 PM
