» Site Navigation
» Other Sites
Old 04-17-2008, 06:02 AM   #11 (permalink)
eric242340
eric242340's Avatar
Date registered: Nov 2007
Vehicle: My feet for now
The shut of valve is located on the lower side of the oil filter casing and very easy to change and thats the first stop. If that does not fix it then move to the timing chain tensioner and oil pump issues, do a search on these two as many cars used the 104 engine, even S Class
If you have been using the wrong oil grade for a long time, then changing to the correct oil grade will not repair the damage. But it may give you better overall oil pressure.
We are moving on up
eric242340 is offline   Reply With Quote
Old 04-17-2008, 06:34 AM   #12 (permalink)
mustangman1992
Date registered: Sep 2006
does anyone know if this check valve is available seperate from the housing ?
mustangman1992 is offline   Reply With Quote
Old 04-17-2008, 07:14 AM   #13 (permalink)
deanyel
Date registered: Jul 2004
Sure, it would be available separately. The EPC would have all the information you need and, assuming you are in the U.S., is free.
https://epc.startekinfo.com/epc/welcome.jsp
deanyel is offline   Reply With Quote
Old 04-17-2008, 07:15 AM   #14 (permalink)
eric242340
eric242340's Avatar
Yes it is and if you give me your vin number I will send your the part number.
Old 04-17-2008, 07:40 AM   #15 (permalink)
Kestas
Vehicle: 95 E320 Cabriolet
How about checking the tensioner? It should be a rather easy and straightforward job. Check to see if it's reached the end of its travel, or if there is anything otherwise wrong with it.
The tensioner is designed to ratchet in one direction only to take up the majority of the slack (i.e., to "rough-in" the tension). This helps keep some tension during startup. After the slack take-up is roughed in, the tensioner further uses the engine's oil pressure to take up the remaining slack after the engine is started. I suspect the tensioner's ratcheting system may be stuck or reached the end of its travel, and the oil pressure is doing all the work. Just a theory.
This message written with 100% recycled electrons.
Kestas is offline   Reply With Quote
Old 04-18-2008, 04:05 AM   #16 (permalink)
eric242340
eric242340's Avatar
Thanks for the VIN and here is your shopping list;
A601 184 01 32 Valve
A102 993 07 01 Spring
A102 184 00 31 Retainer
N000 472 024 000 Lock ring
If you decide to remove the oil filter case to do this job then you will need;
A601 134 05 80 Gasket
After you have changed the valve change your oil and filter. Use mobil 1 synthetic as its much better for your engine.
Old 04-18-2008, 05:27 AM   #17 (permalink)
mustangman1992
thank you soooo much eric !!
Old 04-18-2008, 05:37 AM   #18 (permalink)
mbkomfort
mbkomfort's Avatar
Date registered: Jan 2008
Vehicle: MB 230TE 84-
Could it be the hydraulic cam chain tensioner? i know it can cause trouble on the m102..
mbkomfort is offline   Reply With Quote
Old 04-18-2008, 06:35 AM   #19 (permalink)
deanyel
I've seen some very smart people say to stay away from synthetic oil when you have a tensioner oil leak down problem, specifically in regard to the early 119 motor problem. I suppose it doesn't hurt much to experiment.
Old 04-18-2008, 07:06 AM   #20 (permalink)
eric242340
eric242340's Avatar
Smart people? I am an MB Tech with over 40 years experience and you say EXPERIMENT? We are not discussing the 119 engine. We are talking about the in line 6, 104 engine. These so called (smart people) know about all the modifications for the 104 engine? These so called (smart people) know about the leak down problem?
I dont give advice for fun, these are expensive cars mate If any of my apprentices used the word experiment I would fire him on the spot. That is how seriously I take my job.
HELP! 95 E320 M104 timing chain guide rail pin purplelimo W124 E,CE,D,TD Class 0 02-09-2008 09:47 PM
timing chain slap? john carey W124 E,CE,D,TD Class 2 03-17-2007 03:58 AM
dreaded timing chain slap carsten123 R/C107 SL/SLC Class 2 12-06-2006 05:51 PM
timing chain tensioner slap flathman R/C107 SL/SLC Class 4 09-20-2005 05:42 PM
Ticking engine during acceleratio rattling noice standing still (timing chain, piston slap…?) johan6504 W124 E,CE,D,TD Class 3 03-01-2003 12:52 PM
