Diesel injector torque spec?? - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 04-12-2008, 09:45 AM Thread Starter
Ron Conway's Avatar
Date registered: Mar 2008
Vehicle: 1987 300D Turbo, 260,000+ miles
Question Diesel injector torque spec??
I just purchased a 1987 300D Turbo with 243K miles. It smokes and has a rough idle. I'm going to start by replacing the injectors, heat shields and fuel bypass lines. I don't have a repair manual yet. (waiting for postman to deliver).
Can anyone give me the proper torque spec on the injectors?
Model Year Chassis Engine Hp
W124 300D Turbo 1987 124.133 603.96 147
Thanks in advance.
Ron Conway is offline
post #2 of 5 (permalink) Old 04-14-2008, 04:51 PM
drgreenthumb's Avatar
Date registered: Apr 2007
Vehicle: 95 E300D
Haynes says 75Nm or 55 lb/ft for the injector
drgreenthumb is offline
post #3 of 5 (permalink) Old 04-16-2008, 05:38 PM Thread Starter
Ron Conway's Avatar
Thank you
post #4 of 5 (permalink) Old 04-10-2011, 10:33 AM
Date registered: Dec 2010
compression specs
Hi my name is John and i have W124 300D Turbo 1987 124.133 603.96. Can anyone give me the proper compression cylinder specs for this engine? Thank you in advance.
JTORRES is offline
post #5 of 5 (permalink) Old 04-10-2011, 04:42 PM
fredvillanueva@gmail.com's Avatar
Date registered: Jul 2009
Vehicle: 1985 190d German Cockroach 2.2 M5 395k miles 2004 C240 Wagon Non-4-matic
You may also want to run 2 cans of diesel purge through it and change the fuel filters...made a huge difference on my diesel ... I may be doing the injectors too, but the change the purge made was so great that I don't feel a need to rush... are your vac lines, motor mounts, and throttle cable ok? You have nice car...I would love to get a hold of the wagon version of it...
fredvillanueva@gmail.com is offline
    injector bolt torque setting Oldmanbt V-Class 10 12-07-2014 02:41 PM
    glow plug torque spec xtraag W126 S,SE,SEC,SEL,SD,SDL Class 2 12-29-2007 10:03 AM
    Need a torque spec..... Working on it right now.... :) billabongo W126 S,SE,SEC,SEL,SD,SDL Class 6 08-19-2007 10:02 PM
    98 ML320 Wheel Torque spec. dumokie W163 M-Class 3 06-27-2007 04:30 PM
    What torque spec for the lugs??? lincoln R129 SL-Class 1 01-13-2006 04:23 PM
