What type of oil should I use for my E320 95? - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 04-09-2008, 12:41 AM Thread Starter
Date registered: Mar 2008
Hi, I have E320 1995 and my question is what type of oil should I use for this car? and how many quarts does this car takes when you change the oil?
Synthetic oil are expensive, can I use any non synthetic? if yes!, what brand and SEA are recommended?
Thank you
armenn73 is offline
post #2 of 4 (permalink) Old 04-09-2008, 06:33 AM
Sergio's Avatar
Date registered: Sep 2002
Vehicle: 2001 E320; 2002 ML500
There are plenty of oils you can use. Stick to well known brands. Don't use anything below -40 grade. You can use 10W-40, for example.
I particularly like Mobil 1 synthetic oil and I replace mine every 10K miles with either 0W-40 or 10W-40 high mileage formula. It takes 8 quarts. First put in 7 1/2 and then top off as necessary.
Sergio
'02 ML500
'01 E320 Wagon 4-Matic (R.I.P)
'95 E320 SE (gone)
'99 ML430 (gone)
'94 C280 (R.I.P)
'12 LR4
'02 TAHOE
Sergio is offline
post #3 of 4 (permalink) Old 04-09-2008, 12:52 PM
RBYCC's Avatar
Date registered: May 2005
Vehicle: 88-300CE TWIN TURBO, 99-C43, 05-G55K, 71-280SL, 94-E320 CAB, 08 CLK63 BLACK SERIES
Mobil One is the synthetic that MB uses.
Castrol Syntec is also a good choice.
Weight depends on your climate and the type of driving you do.
5W-40 or 10W-40 is a good safe choice.
TURBOTECHNICS TWIN TURBO M103 WIDEBODY
1971 280SL ROADSTER
1988 300CE TT WIDEBODY COUPE
1994 E320 CABRIOLET
1999 C43 AMG SEDAN
2005 G55K AMG TRUCK
2008 CLK63 AMG BLACK SERIES COUPE
RBYCC is offline
post #4 of 4 (permalink) Old 04-10-2008, 09:01 PM Thread Starter
Thank you
armenn73 is offline
    05 C230K Remove Oil Cap - What type Motor Oil FLBenz W203 C-Class 3 11-06-2007 07:53 AM
    Type of Oil to use in Oil Change Paul Mellerowicz W210 E-Class 17 09-22-2007 07:02 PM
    Oil Change and oil type HyperLite W202 C-Class 3 03-20-2006 06:20 AM
    What type of speaker is in a 97 E320? Ruffrob Audio & Telematics Forum 4 07-31-2004 12:26 PM
    Oil Type for 1995 E320 Touring edro W124 E,CE,D,TD Class 1 06-06-2003 12:14 PM
