Old 04-04-2008, 01:07 PM   #1 (permalink)
Date registered: Feb 2008
Vehicle: 1992 300TE 4MATIC
Question 1992 300TE 4Matic - Oxygen Sensor
Another stupid question guys... sorry!
I need to get a new oxygen sensor and I am going to do it myself. I have the Service Manual CD and I printed out both instructions for replacing the oxygen sensor but they still do not give enough detail.
My question is:
Where the heck is it and how should I replace it? IE: Do I need to rip the carpeting out because I know it is in front of the passenger seat.
Thanks guys!
And sorry again for this stupid question!
CrazyAzn2121 is offline   Reply With Quote
Old 04-04-2008, 07:27 PM   #2 (permalink)
rob76's Avatar
Date registered: Mar 2008
Vehicle: 1989 260E
Well I just did mine on my 260e and the sensor itself is just before the catalytic converter on the exhaust pipe. The wires disappear up into the frame and I assume under the central console. Anyway, it came out easy enough. I bought a NTK sensor that just has butt connectors, so I had to cut the old wires and crimp them together underneath the car. What a job. Hope you have a lot of patience and experience. I think it would still be easier than trying to take the original plug out from inside the car. Plus it cost half as much as the full sensor + plug.
rob76 is offline   Reply With Quote
Old 04-05-2008, 07:14 AM   #3 (permalink)
Jayare's Avatar
Date registered: Jun 2005
Vehicle: 86 190E 2.3 16V, 90 300CE, 93 400E, 02 Olds Aurora
The O2 sensor connection is under the carpet of the passenger front, at the bottom of the transmission tunnel where it joins the floorboard. Lift out the carpet and you'll easily see it. If your going to use a replacement other than OEM, it is better to make the plug/connector "splice" reside inside the car.
Good Luck,
Jayare
Jayare is offline   Reply With Quote
Old 04-05-2008, 12:55 PM   #4 (permalink)
Thanks guys, I'll look into it because my gas mileage is completely AWFUL
Old 04-05-2008, 12:56 PM   #5 (permalink)
And yes I have checked the thermostat, changed the air filter, spark plugs and wires and all that shit.
1992 300TE 4Matic Vs. 2000 E320 4Matic dogwagon General Mercedes-Benz 5 02-27-2007 09:31 PM
1992 300TE 4Matic - need valve block stummala W124 E,CE,D,TD Class 2 12-08-2006 05:13 PM
ALL Sensor abreviations.. Ex: o2- Oxygen sensor skipinschool W210 E-Class 2 10-19-2006 02:22 PM
Considering Buying a 1992 300TE 4Matic graddini W124 E,CE,D,TD Class 2 06-30-2006 08:09 AM
300TE 4Matic to non-4matic conversion hellspcangel911 W124 E,CE,D,TD Class 4 02-13-2006 08:18 AM
