this vac line starts connected to something on the right side behind the blinker, the runs towards the battery and stops - i have no clue where this should go, or if is hurting anything. the end of the line is sealed.
Thanks
Reason: better title
Is the end that is connected hooked up to a switching valve? There should be a switching valve near the corner marker as you described.
A switching valve would also have an electrical connector plugged into it, and probably another vacuum line connected to it too (in case you wouldnt recognize a switching valve)
If it IS hooked up to a switching valve, then YES, you need to find out where the disconnected end goes.
There should be a vacuum routing diagram sticker somewhere on your upper core support for refrence.
i believe that is the vacuum tube for the headlight level adjuster. My european model has the same color tube and it plugged in to the headlight casing. do you have a wheel button next to your headlight switch? that should be the headlight level adjuster. thx
