Old 03-21-2008, 09:05 PM   #1 (permalink)
Date registered: Jan 2007
Vehicle: 1997 S420 55K, 1994 E320 Cabriolet 13K
Won't start
My 1994 E320 Cabriolet with only 13K miles on it won't start. I drove it in the garage a month ago. It cranks fine but absolutely no firing. Is there a fuel relay or some obvious fist step I should do before calling for repair. In all respects the car is as new, no wiring harness problems etc. It has to be something simple doesn't it? I don't smell any gas like it is flooding either.
JohnMichael is offline   Reply With Quote
Old 03-21-2008, 10:29 PM   #2 (permalink)
E430SportMB's Avatar
Date registered: Dec 2007
Vehicle: 2000 MB
Look at the DIY section for cps. It might be it.
I believe I think, so therefore, I think I believe !
E430SportMB is offline   Reply With Quote
Old 03-21-2008, 11:30 PM   #3 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
Hi, John.
How was the car running before you parked it? Flawlessly or were there any odd symptoms, even if fleeting? That's a long time to park it, did you disconnect the battery or put it on a charger, or?
Post back up with some more detail and hopefully we'll get you pointed in the right direction.
Take care and enjoy the ride,
Greg
Old 03-22-2008, 12:02 AM   #4 (permalink)
JOE55's Avatar
Date registered: Nov 2004
Vehicle: E55 ///AMG
call the MB Roadside Service they can help you out on the spot to figure out whats wrong.
JOE55 is offline   Reply With Quote
Old 03-22-2008, 12:13 AM   #5 (permalink)
ohlord's Avatar
Vehicle: 99 e320 wagon,bmw,vw,mgb,mg midget,subaru wagon
W124
with the pesky m104 harness,been sitting around in the garage?Take a look at the wiring harness if it falls apart just from you looking at it therein lies your problem.Start there.Report back with results of what it looks like.Don't bother with the crank position sensor you don't have one on the m104.
ohlord
you might want to visit the w124 forum also the w124 forum on mbworld.org
It cranks so it can only be no fuel or no spark.Checked all fuses?
Keep your fingers crossed that it is not the EZL
the harness can also look fine on the outside and be powder on the inside.
Have you charged the battery?You could remove the maf and spray some starter fluid into the intake tube and then when it starts reinstall the maf so it does not get affected by the starter fluid.
Old 06-08-2008, 01:33 PM   #6 (permalink)
RES
Date registered: Sep 2003
Vehicle: C230 Kompressor
John,
I have a similar starting problem like the one you described on your E-class with my C220. Mine has problems starting after it has sit for a few days. Cranks fine but takes mutiple tries of cranking shutting off and trying again before you can get it to start. If you turn it off once it has started it works great, until it sits again for a day or more. Checked codes and all systems reported normal. I was wondering if you ever got to the bottom of your problem?
Thanks,
Robert
RES is offline   Reply With Quote
Old 06-08-2008, 04:33 PM   #7 (permalink)
I posted this problem weeks ago so have no idea how it appeared today. Anyway I locked an unlocked the doors and it has started everytime ever since. Think the alarm system shut off the gas when it got a low battery but never heard the alarm.
HELP! S-320 will not start! but finally got to start with direct power to starter Newinport W140 S-Class 8 03-21-2008 09:58 PM
Is it possible to push start [ Tow start] an Auto Mercedes ? blitzgritz W123 E,CE,D,CD,TD,TE Class 6 07-04-2007 12:35 PM
sl500 cold start fine-short trip park restart rough idle hard start?? dpol1835 R129 SL Class 7 01-02-2006 06:33 AM
Hard start or second start when warm high hc level-- beware major expense Peter Seow W126 S,SE,SEC,SEL,SD,SDL Class 1 07-03-2004 06:23 PM
Should my 1989 190e start in 2nd gear unless floor it from start? Guest (MBNZ) W201 190E, D-Class 5 08-01-2002 12:27 PM
