Dashboard lights out 1994 E320 - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 03-19-2008, 06:30 PM Thread Starter
Date registered: Feb 2008
Hello fellow enthusiasts,
My dash lights (the lights that illuminate the switches), the radio illumination and my instrument panel lights are all out. All the other things that are connected to the relevant fuse in the fusebox are fine (license plate light, seatbelt warning module etc.). Any advice is greatly appreciated!
Anandj is offline
post #2 of 5 (permalink) Old 03-20-2008, 07:04 AM
RBYCC's Avatar
Date registered: May 2005
Vehicle: 88-300CE TWIN TURBO, 99-C43, 05-G55K, 71-280SL, 94-E320 CAB, 08 CLK63 BLACK SERIES
Turn the instrument cluster dimmer switch ( lower left from speedo ) to the right.
It's the same knob that pushes in to reset the mileage.
Too often when you reset you also turn left and dim the lights to off.
TURBOTECHNICS TWIN TURBO M103 WIDEBODY
1971 280SL ROADSTER
1988 300CE TT WIDEBODY COUPE
1994 E320 CABRIOLET
1999 C43 AMG SEDAN
2005 G55K AMG TRUCK
2008 CLK63 AMG BLACK SERIES COUPE
RBYCC is offline
post #3 of 5 (permalink) Old 03-27-2008, 05:49 PM Thread Starter
Thanks so much! Can't believe that's all it was. I have since bought an owner's manual to prevent any more ignorance-related issues.
Anandj is offline
post #4 of 5 (permalink) Old 09-09-2010, 11:34 PM
Date registered: Aug 2010
Vehicle: 1995 Mercedes-Benz E320 Sedan, Special Edition
Perfect!
Can't believe this either! I was expecting to retrace the path after replacing my engine wiring harness. Just turn the knob! I've had this car for 6 years and had not idea. Thank you!!
quest1966 is offline
post #5 of 5 (permalink) Old 09-10-2010, 09:52 AM
macdrone's Avatar
Date registered: Nov 2006
Vehicle: 1993 400E 23100 miles "Gunter", 1999 ML320 200000 miles "Fizgig"
RBYCC you and your knowlege of the owners manual!!! curse you!!! just kidding. Good job with the speedy help out.
Just a suggestion all if you dont have the owners manual find a digital copy, download and print it out. Its got alot of easy answers like fluids how much and some part numbers and sizes.
macdrone is offline
    Flickering console lights 1994 e320 Cabrio swanny2070 W124 E,CE,D,TD Class 1 11-16-2006 01:06 AM
    1994 E320 Dashboard Speakers Replacement Hamid Audio & Telematics Forum 1 11-07-2006 11:04 PM
    No dashboard lights? dieselpowered W126 S,SE,SEC,SEL,SD,SDL Class 6 09-08-2005 08:41 AM
    Dashboard Lights.... Fan2zee R129 SL-Class 2 02-11-2005 06:23 PM
    2003 E320 OEM 16" => 1994 E320 with HUB CENTRIC SPACERS melon_stunner The Discount Tire Direct Tire, Wheel, Brake & Suspension 1 01-14-2004 09:02 AM
