» Site Navigation | | » Other Sites | » Search Used Cars | |
| » Network Links | | | | » Wheel & Tire Center | | | | Sponsors | | | |
03-14-2008, 09:34 PM
#1 (permalink)
| | BenzWorld Member
Date registered: Jun 2007 Vehicle: 1981 Mercedes 380SL & 1994 Mercedes E320 Wagon & 1993 Jaguar XJ6 Location: Northcoast Eureka, CA
| The combo relay....... .......does it also control the high beams? When I flick the high beam switch forward, the headlights go out instead of the high beams coming on.
dws
__________________ CUPDGRA
TYPE107 |
| Advertisement
03-15-2008, 03:52 PM
#2 (permalink)
| | BenzWorld Senior Member
Date registered: Nov 2006 Vehicle: 1993 400E 209000 miles Location: Great Lakes
| Yes |
| Advertisement
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | | | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | |
Similar Threads | | Topic | Author | Forum | Replies | Last Post | | Need a visual on combo relay location..... | NorCalSL | W124 E,CE,D,TD Class | 2 | 03-16-2008 06:31 AM | | Replaced Fuel Relay- Can't get Air Compressor relay to sit flush with it | DubVBenz | W126 S,SE,SEC,SEL,SD,SDL Class | 1 | 02-20-2008 09:58 PM | | P1453 AIR relay module AIR relay module in passenger-side fuse and relay module box ? | Bansai | W210 E-Class | 4 | 05-07-2007 10:07 AM | | Combo relay bd location | shingleback | W201 190E, D-Class | 0 | 10-20-2006 07:04 AM | | Wiper relay/combo switch | 95e320cab | W124 E,CE,D,TD Class | 3 | 09-22-2002 08:29 AM | |
