» Site Navigation » Other Sites
03-08-2008, 09:56 PM
#1 (permalink )
Date registered: Jun 2007
Vehicle: 1981 Mercedes 380SL & 1994 Mercedes E320 Wagon & 1993 Jaguar XJ6
W124-Is there a turn signal relay?
I have an intermintent non-operational turn signal problem. I have checked the bulbs and the switch feels fine. If there is a relay, where is it located?
dws
__________________ CUPDGRA
TYPE107
03-08-2008, 11:39 PM
#2 (permalink )
Originally Posted by
NorCalSL I have an intermintent non-operational turn signal problem. I have checked the bulbs and the switch feels fine. If there is a relay, where is it located?
dws
What year is your car model? If your car is in 1986 to 1992 line production, you may check the fuse for turn signal lights. The fuse's location is in the fuse panel and fuse number is "6" (it controls the turn signal, outside temperature gauge and horns). If there's no problem with the fuse, you should check the exterior bulb monitoring module, located in the panel behind the fuse panel. Hope it help.
03-09-2008, 07:23 AM
#3 (permalink )
Date registered: Jun 2005
Vehicle: 86 190E 2.3 16V, 90 300CE, 93 400E, 02 Olds Aurora
You have a relay for the turn indicators. Located under the dash, near the steering column I believe. Part number is from autopartsplace.com
Additional Notes: Multi-function relay used for blinker : hazard warning : heated rear window : wiper .
Fits: All Types
What is a Core Price? Click Here
Part Number: P2020-32725
Germany
Click for Full Picture
Description:
Relay
List Price: $139.00
Core Price: $0.00
Your Price: $89.68
Status: In Stock
Ships: Today
Good Luck,
Jayare
03-09-2008, 08:11 AM
#4 (permalink )
Date registered: Oct 2006
Vehicle: 95 C280 Silver Metallic(champagne), 89 300E Onyx Mettallic<< All Options both w/car phones
I would check with dealer just in case i got quoted $69 for one of my service relays
03-09-2008, 08:16 AM
#5 (permalink )
Date registered: Mar 2008
Vehicle: 2002 Mercedes-Benz E320 4-Matic for snow, 2006 ML350, 1990 190E, and 1993 300E
TURN SIGNAL RELAY
If I'm not mistaken...it's located under the hood...it's on the left side fuse box on W124 Body. It's called a Combination Relay...
take care,
Mar L. Barruel III, MBA (Master in Business Administration)
Factory-Trained Mercedes-Benz Technician
ASE and MECP Master Technician
Owner and Technician Specializing in M-BENZ
website:
MARS Automotive Group
Thread Tools Display Modes Linear Mode
Similar Threads Topic Author Forum Replies Last Post 69 280SE turn signal relay is where exactly ??? rvm67 Vintage Mercedes-Benz 2 10-19-2006 07:31 AM Turn Signal Relay Minkoff W126 S,SE,SEC,SEL,SD,SDL Class 0 05-09-2006 10:29 AM C280 Turn Signal Switch or Relay ? mogmedia W202 C36 AMG, C43 AMG 0 01-12-2006 04:58 AM Turn Signal Relay jmai W126 S,SE,SEC,SEL,SD,SDL Class 1 11-13-2005 12:27 PM Should the turn-signal relay be that silent? Guest (MBNZ) R/C107 SL/SLC Class 12 08-14-2005 07:57 PM
