» Site Navigation
» Other Sites
Old 02-29-2008, 07:29 AM   #1 (permalink)
Date registered: Feb 2008
technical help
Hi all. New to Benz and to this forum. I'm sure these questions have been covered in detail before, but I would appreciate any guidance.
300E, 6 cyl. auto, showing 160k. Rough idle, dies at idle periodically, smooth as silk at highway speeds. Lifters seem noisy. Power level seems somewhat low. I've done the standard i.e. checked for vacuum leaks, changed oil, new wires & plugs, etc. Compression good.
Also, the odometer & tachometer do not work, and the (I think) oil level light stays on.
Any help appreciated.
Steve
steview is offline   Reply With Quote
Old 02-29-2008, 08:34 AM   #2 (permalink)
Date registered: Jan 2008
Vehicle: 1993 190e-2.3; 1992 300E-3.0, 1998 Saab 9000T
It could be the ignition coil. I had a bad one and it was fairly hard starting, both cold and warm, had a slight miss at idle, periodically stalled at lower speeds, ran great on highway. Replaced coil and it started right up and now runs great.
GPost is offline   Reply With Quote
Old 02-29-2008, 10:08 AM   #3 (permalink)
Vehicle: 95 E320 Cabriolet
Dirty throttle body bore? It's an easy, no-cost procedure to clean it.
This message written with 100% recycled electrons.
Kestas is offline   Reply With Quote
Old 02-29-2008, 01:27 PM   #4 (permalink)
GHM
GHM's Avatar
Date registered: Jul 2005
Vehicle: 1986 300E 3.0
Dirty Throttle
A little more detail on the process, please. Thank you
GHM is online now   Reply With Quote
technical question g-class merv Mercedes-Benz Motorsports & Racing 1 10-04-2006 09:39 AM
Technical Information nesa W163 M-Class 1 11-12-2005 04:54 PM
SL Technical Forum Guest (MBNZ) R230 SL Class 4 02-11-2005 12:14 PM
Technical PDFs SLicK350 R171 SLK Class 0 02-01-2005 04:46 AM
Technical difficulty Guest (MBNZ) W202 C-Class 1 10-04-2000 08:48 AM
