» Site Navigation
» Other Sites
Old 02-25-2008, 04:11 PM   #1 (permalink)
jmoney6's Avatar
Date registered: Feb 2007
Vehicle: 300e 4Matic
300e not performing so well
Ok i have a 93 300e 4MATIC. my roomate has an 88 300e. essentially the same motor. I was just wondering should his 300e perform much better than mine. Because mine is heavier. Or should they accelerate just about the same
jmoney6 is offline   Reply With Quote
Old 02-25-2008, 05:52 PM   #2 (permalink)
Date registered: Sep 2006
i though the 93 had the 104 engine.... if it does..it should be quicker.
We have three 103's. the quickest is the 300e... the 300ce is next.. then the 260 (less horsepower...noticibly slower)
1988 260E 215k miles (mine)
1989 300CE 168k miles (wifes)
1989 300E 180k miles (son's)
1998 Ford Expedition 167k miles (semi-retired)
Sold: 1972 280SE 4.5 153k miles. The car that started my passion for simple, well made automobiles.
lee polowczuk is offline   Reply With Quote
Old 02-25-2008, 06:24 PM   #3 (permalink)
Campo09's Avatar
Date registered: Aug 2007
Vehicle: 1986 Mercedes-Benz 300e
Send a message via AIM to Campo09
the 93 300e 4 matic is slower because it weighs more and uses the m103, which either produces 177hp or 185hp. the 88 300e has the same engine but weighs less.
..::1986 Mercedes Benz 300e::..
Campo09 is offline   Reply With Quote
Old 02-25-2008, 06:58 PM   #4 (permalink)
Date registered: Jul 2004
I saw a chart somewhere that had the 1988 300E as the lightest ever 124 (U.S. market) - under 3,100 pounds as I recall. It would be considerably faster than a 93 4-matic with the same 177 hp engine.
deanyel is offline   Reply With Quote
Old 02-25-2008, 07:10 PM   #5 (permalink)
jmoney6's Avatar
i was just wondering, i figured that because it was lighter but i thought maybe mercedes pushed some extra power out of the motor. I dont know i was just curious and deanyel thanx again bro ur a life saver
Old 02-25-2008, 09:24 PM   #6 (permalink)
Date registered: Oct 2007
Keep in mind that the 4 wheel drive system adds weight, but it's also costing you more power to drive the system. It's simple really, you have more frictional losses and more parasitic losses therefore your friends car should be faster than yours even if you make 8 more HP than he does.
Nasty Nate is offline   Reply With Quote
Old 02-26-2008, 03:43 AM   #7 (permalink)
augapfel's Avatar
Date registered: Jan 2006
Vehicle: 88 260E, 88 300E x 2, 88 300TE x 2
Were the 4Matic cars geared differently (differential ratios)?
augapfel is offline   Reply With Quote
Old 02-26-2008, 06:42 AM   #8 (permalink)
Not sure where the 8 hp came from but they are both 177 hp / 188 ft lbs.
Old 02-26-2008, 09:21 AM   #9 (permalink)
Campo mentioned 177hp and 185hp.
Old 02-26-2008, 11:34 AM   #10 (permalink)
jmoney6's Avatar
185 is euro spec no cats or smog pump i think.
"My car has power everything, EXCEPT under the hood"
How is the new W221 performing? SSL W221 S-Class 4 05-25-2006 09:46 AM
Are Our Engines Performing to Their Full Capabilities? MorrisTigerson69 W126 S,SE,SEC,SEL,SD,SDL Class 4 04-30-2005 10:30 AM
Custom- how's the new car performing? Robbie R170 SLK Class 2 10-07-2003 04:25 PM
Poor performing SLK 32 any thoughts? Tim R170 SLK Class 19 08-28-2001 02:50 AM
Periokid, how's the SR1 performing so far? Any issues with it? Thanks. Arnee R170 SLK Class 4 05-29-2001 02:05 PM
