Old 02-21-2008, 10:05 AM   #1 (permalink)
bschleic57's Avatar
Date registered: Jun 2006
Vehicle: 84 300SD, 225k miles and still kickin' 86 300E smoke silver/java 65k orig miles
86 300E exhaust replace
just bought a low miles (65k) 1986 300e and the original rear muffler is shot. How difficult is it to DIY this repair? I have minimal tools and fair car repair skills. Does the rear muffler fit inside the middle muffler at the slip joint? Would a hack saw suffice? wjere can you jack the car with floor jack? I'm mostly an old Mopar guy so far humor me!
Vielen Dank!
Bill
bschleic57 is offline   Reply With Quote
Old 02-22-2008, 10:22 PM   #2 (permalink)
pjwebb's Avatar
Date registered: Jul 2004
Vehicle: '85 300E. unaltered and original. 276,000 kms
Hello Bill.
That's one of the good things about this forum: there are all sorts of 124 owners with differing levels of experience and knowledge, all with the one common interest. We all had to start somewhere, even the professionals. I must add that I am not a professional, far from it, and that I've found contributions to this forum very helpful.
Rear muffler entry pipe goes over end of middle muffler exit pipe (resonator? Someone please correct.) and is secured with u-clamp (mine is, anyway.) New rubber hangers are a matter of course, and put the trolley jack lifter under the big rubber blocks which are under the car just in from the sills, and for that very purpose. The blocks are in line with the capped points built into the sills to accept the wheel-changing jack. They thought of very nearly everything...
pjwebb is offline   Reply With Quote
1990 300E radio replace Karebear300E Audio & Telematics Forum 2 10-05-2006 01:40 AM
Failled Emissions, Replace exhaust? abentley79 W124 E,CE,D,TD Class 2 02-25-2006 05:42 AM
Replace Waterpump on 1989 300E preston32 General Mercedes-Benz 2 10-20-2005 06:05 AM
replace a/c or part of for 300E 1990 dianetrot W124 E,CE,D,TD Class 3 06-15-2004 08:32 AM
'86 300E rear-ended. Replace or Fix??? sdgrossman1 W124 E,CE,D,TD Class 6 11-25-2003 07:03 PM
