» Site Navigation
» Other Sites
Old 02-16-2008, 11:37 AM   #11 (permalink)
Date registered: Mar 2007
Vehicle: Mercedes-Benz 280TE 1993
Hi Deanyel
I pulled out the vacuum line (engine running) from the fuel pressure regulator but it did not smell of petrol at all.
Fernandez
Fernandez is offline   Reply With Quote
Old 02-16-2008, 12:15 PM   #12 (permalink)
Date registered: Jul 2004
Originally Posted by Fernandez View Post
Hi Deanyel
Fernandez
I would try it again cold, just to be sure.
deanyel is offline   Reply With Quote
Old 02-18-2008, 10:31 AM   #13 (permalink)
Hi Deanyel
When I pulled the line out of the fuel pressure regulator the engine was cold (after a frosty night).
Now, what do you think of this?
When I went back to the garage to pay the bill the boss told me he had been thinking of my problem. He said there was another possibility to explain the symptoms.
He said my engine had some difficulty with the oil reaching the top of the engine. That could lead to the hydraulic valve lifters being starved of oil. As a result, the valves could not open properly to the point of the engine being unable to fire up. At the same time, as fuel would still be injected in the manifold, once the valves resumed normal function a significant excess of fuel would get in the combustion chambers causing them to flood. He thinks this could be serious enough to render the ignition system unable to ignite this over rich mixture, hence the strong smell of unburnt petrol.
According to him, this could explain why the problem occurs first thing in the morning but never throughout the rest of the day even if it was cold and the car was not in use for hours. This could also explain why it does not correlate well with outside temperatures.
Any comments are very welcome.
Thanks
Fernandez
240D cold start problems AZMT123 W123 E,CE,D,CD,TD,TE Class 14 05-12-2008 07:48 PM
cold start problems?????????????????? perday W201 190E, D-Class 7 03-01-2006 12:18 PM
240D cold start problems babatino W123 E,CE,D,CD,TD,TE Class 13 01-15-2006 11:29 AM
cold start problems GM3 G-Class 14 01-14-2005 02:43 AM
300ge cold start problems ianwatsoni G-Class 3 10-04-2003 10:30 PM
