» Site Navigation
» Other Sites
Old 01-28-2008, 02:34 AM   #1 (permalink)
Date registered: Jan 2008
Post 230 TE 1988 wont start
My 1988 mercedes 230 TE wont start after the mechanic tampered with the Bosch KE Jetronic Misxture Control Unit Adjustment. He cant get it back to the position from where he turned the screw with the allen key as he did not count the turns cw / ccw. This was done as the car would hard start and would go off if the accelerator was released.
The engine cranks well but does not fire and the clyinder and spark plugs are getting flooded with petrol.
The VIN No is WD 124083 2F 072560.
Any suggestions on how to get the mixture adjustment to its original setting or on how to get the engine to start.
tombanon:
tombanon is offline   Reply With Quote
Old 01-28-2008, 07:08 AM   #2 (permalink)
Yal
Date registered: Sep 2004
Turn the screw counter clockwise to make it lean. You're going to have to change your spark plugs or leave them out to dry now that they are covered in petrol.
If you are going to play around with the screw then you need to monitor the dutycycle reading while you are doing it. See the following link...
BOSCH KE3-JETRONIC MIXTURE ADJUSTMENT
Yal is offline   Reply With Quote
Old 01-28-2008, 07:42 AM   #3 (permalink)
Thanks for your reply Yal - we have tried to adjust it counter clockwise but to no effect although it has been turned totally - the flooding continues and eginge does not start. We have already seen the link mentioned by you but I am in a place were I dont have a dutycycle measuring tool - what can I use to moniter this duty cycle? I have replaced the plugs but this has not made any difference.
Tom banon
Old 01-28-2008, 01:51 PM   #4 (permalink)
Yal
You can buy a cheap multimeter with % duty cycle readings.
How are your ignition components? How is the distributer and rotor?
Old 01-28-2008, 10:07 PM   #5 (permalink)
Post 230TE - 1988
Yal The Ignation is ok as I have tried a new coil, rotorcap, plugcabels and new spark plugs. There is a strong current at the coil output and at the spark plugs. The fuel pump is working fine and the injectors are also ok.
I drove the car for about 600 kms from Delhi -India in a day to my home town Manali and it performed well. The next morning it started hard and as soon as the accelator was released it would cut off. So I called up the service center at Delhi who are maintaining this car for the last 10 years since I have had it and they sent up the new parts and asked me to get a local mechinic and ask him to open the auxiliary air idle valve by two threads due to the difference in the altitude.
The mechanic persumed that the air mixture screw was the air idle valve and he turned it antoclockwise and since that point it cut off and would not start. He than turned the screw clockwise and acw without counting the threads/turns. On leaning it fully acw it has no effect- still flooding.
I have a simple multimeter with amps/mamps,volts DC/Ac, Ohoms but no duty cycle and I am trying to have one sent up from Delhi after reading your reply. In the meantime an examination of the X11 diagnostic connector I find that all the pins have metel points except for pin 3 which is a plastic hole- what does this mean?
Thanks again for your help which is greatlly appreciated as this is the only merc in this area and the mechanics have no knowlege of the system
Tom Banon:
Old 01-29-2008, 07:04 AM   #6 (permalink)
Yal
If you have nothing in pin 3 I believe it means you don't have a lambda signal. Does this car have an oxygen sensor? Probably not right?
I would monitor the EHA and the Idle Control Valve and see if they are doing anything.
Mercedes-Benz Driveability Evaluating Electronic Engine Controls
Old 01-29-2008, 07:41 AM   #7 (permalink)
The fuel system is a Jetronic KE how ever I dont know if it has an oxygen sensor or lambada signal.
Have gone thru the link that you suggested - more tools that are not available here.
looking for wiring diagram 1988 230/300e derekmcbenz General Mercedes-Benz 1 09-01-2007 12:54 AM
Wont start!? glynn09 W210 E50 AMG, E55 AMG 3 06-25-2007 09:54 AM
After wire harness change temp gauge wont work, and now wont start daanmuller W140 S-Class 4 06-14-2007 08:00 AM
Start, ran, wont start again horsessmellfunny W123 E,CE,D,CD,TD,TE Class 9 09-06-2006 08:58 PM
1988 420SEL 114,000 engine suddenly dies wont restart william.wood W126 S,SE,SEC,SEL,SD,SDL Class 11 11-11-2005 02:46 PM
