» Site Navigation
» Other Sites
Old 01-27-2008, 09:17 PM   #1 (permalink)
Date registered: Jan 2008
ThE B l e E d I N G edGe
Let it Bleed. OK, I have a W124 '93 300E 3.2L. Project is to replace the rear wheel set of brake pads and well worn dics. Mistake I made, discovered after I replaced the pads, was that I completely removed the caliper and split the 2 sides (opened) to access the old pads for removal. Should have knocked out the 2 guide pins and removed pads, which would not have allowed air into the lines. I thought the air would be easy to bleed out, which I've easily done before on countless makes and models. Problem is while using the brake pedal to bleed the brakes per standard procedure (rears calipers only) very little air and fluid is coming out of the brake bleed screw, sometimes nothing at all. The brake pedal just mushes down to the floor without any firmness building up. I removed one of the rear wheels to observe the caliper/brake pads while brake pedal actuated, but the caliper pistons did move. Next plan is to bleed the front calipers, thinking air traveled to the front brake lines. Any advice would be very much appreciated. Thanks! Mike
pizza_king is offline   Reply With Quote
Old 01-27-2008, 09:28 PM   #2 (permalink)
neanderthal's Avatar
Date registered: Dec 2003
shouldna taken apart the calipers.
you only want to do that in very specific situations. much easier to just replace the calipers than rebuild them.
'O=00=O' BMW 2002. long live the legend.
neanderthal is offline   Reply With Quote
Old 01-27-2008, 10:59 PM   #3 (permalink)
Thanks anyway, but not planning on replacing or rebuilding the calipers. No indications that its needed at this time. Mike
Door edge guard ZĂ© Bocaina W123 E,CE,D,CD,TD,TE Class 11 09-16-2007 09:00 AM
Softtop Fraying @ Edge Cording JohnDB R129 SL Class 1 07-12-2007 04:08 PM
Trunk Edge Protector silverml500 W163 M-Class 3 10-10-2006 07:14 AM
Door edge moulding 500MPL W208 CLK Class 0 01-31-2004 04:17 PM
Balding outside edge of tire Guest (MBNZ) W201 190E, D-Class 3 06-12-2002 09:37 AM
