» Site Navigation
» Other Sites
Old 01-16-2008, 08:19 PM   #1 (permalink)
Date registered: Jan 2008
Vehicle: 95 E220
surging + overrevving idle
Hi All,
Another problem with this 1995 E200 that has popped up.
Symptoms:
Surge+Hesitation on freeway - can feel car slowing down then speeding up
Uneven Idle - sometimes its fine, other times it will shoot up to 1800rpm
Buzzing noise coming from black box on top of engine, AFM?? when IGN=on
Vacuum noise coming from somewhere on slight push of accelerator pedal.
So I guess the main one is this buzzing noise from the air flow meter, I am assuming thats what it is, its mounted to the throttle body. If ppl have a picture of the W124 engine I can point it out.
I think once I fix that buzzing my other problems will go away.
Advice?
Cheers
David
Tephra is offline   Reply With Quote
Old 01-17-2008, 06:05 PM   #2 (permalink)
Date registered: May 2003
Vehicle: E320 wagon
The idle could be injector O-rings ,also the Mass air flow sensor . Fog the throttle body throat with carb cleaner in short basts , let the engine RPM recover . Then see how it runs .
Uboater is offline   Reply With Quote
Old 01-23-2008, 07:16 PM   #3 (permalink)
Vehicle: 95 E220
thankyou - that seems to have worked.
no more surge/hest on the freeway or taking off at lights.
I do however still have a funny Idle, sometimes it will want to idle @ 1.5-2k rpm when I stop at lights, of course being in Drive negates this, but if I put it into Neutral then the RPMs rise for about 10 seconds before dropping down.
any ideas on this one?
cheers
d.
Surging Idle bigdon W126 S,SE,SEC,SEL,SD,SDL Class 2 07-24-2007 01:06 PM
Idle surging fixed! chomperdog W124 E,CE,D,TD Class 1 06-15-2007 03:16 PM
surging idle floridabenzboi W123 E,CE,D,CD,TD,TE Class 25 03-24-2005 10:06 PM
Idle Surging John Hermann W126 S,SE,SEC,SEL,SD,SDL Class 1 11-21-2002 06:55 PM
2.6 and 3.0 idle surging Guest (MBNZ) W124 E,CE,D,TD Class 2 02-17-2002 05:38 AM
