Old 01-08-2008, 02:24 PM   #21 (permalink)
Date registered: Sep 2006
Originally Posted by JJB236 View Post
So, it looks like many guys here have already went through with this problem... What's your mileage when this happened?
Were there other incidents that made your car to make you stranded? As I said previously, I only became stranded twice in 16 years of ownership. First time was due to a broken distributor cap that made me stranded in the freeway. That time, the engine gradually lost power and I was able to slowly decelerate to the shoulder.
What more problems can I expect to see (197K miles 1991 300E) that will make our cars stall, so that I could take some preventive measures and have parts replaced?
Cheers!
I would get a couple of cans of bg44k. I use it once a year. at mid year interval i use a bottle of techron.
i would carry a spare fuel pump relay. As a preventative measure you might consider changing the fuel filter. That said, I have one on the shelf and I haven't changed any of mine.
I am sort of lucky. when one of my cars has an issue, i can pick and pull from another and trouble shoot that way..
1988 260E 215k miles (mine)
1989 300CE 168k miles (wifes)
1989 300E 180k miles (son's)
1998 Ford Expedition 167k miles (semi-retired)
Sold: 1972 280SE 4.5 153k miles. The car that started my passion for simple, well made automobiles.
lee polowczuk is offline   Reply With Quote
Old 01-08-2008, 03:32 PM   #22 (permalink)
JJB236's Avatar
Date registered: Feb 2006
Vehicle: 91 black 300E (from college days), 01 Vette, 01 Porsche 911, 08 Porsche 911
bg44k? I'll check it out.
wow, you got a stable of nice E's in your family. Very nice.
JJB236 is offline   Reply With Quote
Old 01-08-2008, 04:33 PM   #23 (permalink)
I like cars that I can understand, and that are easy to work on.... my son is becoming quite knowledgeable at the age of 20.
Past 1995, i don't think I will own a Mercedes, since I don't understand electronics.
In the past year, we put 1200 dollars in parts and maintenance in the three.... about 37,000 miles of use.... about .03 mile.... depreciation... maybe 500 dollars among the 3.
Good luck
Old 01-09-2008, 06:21 PM   #24 (permalink)
Date registered: Dec 2007
I bought a 1989 300E, after the paperwork was done I drove it straight to the gas station to fill up. When I went to start it it turned over but did not try to start.
I remembered from one of these forums I had read the day before that the computer would not work without enough voltage. I pushed the car over to the side of the station and walked the half mile home. After attaching the jumper cables and letting the battery charge for five minutes the engine started right away.
Before I bought the car it had spent time sitting on the lot, going on short drives around the block never getting a full charge. I took it back by the car dealer and told them what had happened and the owner took his battery voltage tester out to the car and tested the battery which had just over twelve volts by this time, after an hour driving. With the engine running the voltage was 13.7 which is right where you would want it to be.
With a Battery Minder which charges at a low voltage it took almost a day to reach full voltage.
I would buy a voltage tester to keep in the glove box. It will answer many questions about how much voltage you have and if the alternator or regulator is working.
Norton992 is offline   Reply With Quote
99' E320 - need help - car died on freeway... E-3-Dub W210 E-Class 6 11-18-2006 07:19 AM
1995 sl500 died on freeway? minn500sl R129 SL Class 6 05-06-2006 04:35 PM
300E gauges/door locks have all died partenr W124 E,CE,D,TD Class 5 07-05-2005 09:52 PM
86 300E started fine then stopped dead? Guest (MBNZ) W124 E,CE,D,TD Class 9 08-05-2002 11:07 PM
'86 300E Aux. Fan Just Died! Guest (MBNZ) W124 E,CE,D,TD Class 5 07-18-2002 01:16 PM
