» Site Navigation
» Other Sites
Old 12-24-2007, 02:19 PM   #1 (permalink)
kasteveb
Date registered: Dec 2007
Vehicle: 1993 300E
1993 300E Will not Start/ASR HELP!!
Today I started my 1993 300E and upon start-up the ASR light came on. Thinking this may have been a computer issues, I turned off the ignition to re-start the car to see if the light would go off. When I tried to re-start the car it would not start/would not even turn over, it was if something completely disabled the car from turning over.
Also, the ASR light that you can turn off an on (has a tire with chains on it) is lit up and I cannot turn it off.
I need help! Where do I start? Could it be a fuse/relay?
Thanks for any help anyone can provide me.
kasteveb is offline   Reply With Quote
Old 12-25-2007, 05:06 AM   #2 (permalink)
mariot
Date registered: Nov 2006
You are probably right. It gat to be som cheap fuse. Probably the ones that are located outside the fuse box. How to locate it I cant help atleast right now. Good luck.
mariot is offline   Reply With Quote
1993 300E Will not Start/ASR HELP!! kasteveb W124 E,CE,D,TD Class 3 12-25-2007 06:11 AM
Anyone ever done front brake pads/rotors on 1993 300E/W124? Tips before I start? marshamk W124 E,CE,D,TD Class 2 05-31-2007 09:23 PM
Asr 1993 600sl akelboyz R129 SL Class 5 01-05-2007 03:21 PM
1993 300E 2.8 No Start after opening Relay Box mblink W124 E,CE,D,TD Class 10 11-07-2006 05:44 AM
1993 600 sl asr light peter hamlett R129 SL Class 0 08-06-2003 08:13 AM
