» Site Navigation
» Other Sites
Old 12-24-2007, 11:33 AM   #1 (permalink)
Date registered: Dec 2007
Vehicle: 1993 300E
Exclamation 1993 300E Will not Start/ASR HELP!!
Today I started my 1993 300E and upon start-up the ASR light came on. Thinking this may have been a computer issues, I turned off the ignition to re-start the car to see if the light would go off. When I tried to re-start the car it would not start/would not even turn over, it was if something completely disabled the car from turning over.
Also, the ASR light that you can turn off an on (has a tire with chains on it) is lit up and I cannot turn it off.
I need help! Where do I start? Could it be a fuse/relay?
Thanks for any help anyone can provide me.
kasteveb is offline   Reply With Quote
Old 12-24-2007, 12:01 PM   #2 (permalink)
Date registered: May 2003
Vehicle: E320 wagon
There is a fuse that will kill the starter relay , its labeled something obscure - Key - dash lights - key lock ? Its key switch - relay -battery -starter would be the components to check . If you hear the starter relay clink , hit the starter rear end with a hammer once , the brushes could be shot and it may turn over.
Uboater is offline   Reply With Quote
Old 12-24-2007, 12:17 PM   #3 (permalink)
Vehicle: 1993 300E
Thanks for the reply.
Where are these fuses/relays located on a 300E?
Also, if it were the starter, why would the ASR light be coming on and the ASR switch be stuck? I will check the relays/fuses however where are these located?
Old 12-25-2007, 06:11 AM   #4 (permalink)
Vehicle: E320 wagon
The fuse relay boxes are just
in-front
of the dash /on the drivers side - a long black box in the engine compartment .Behind it are the relays .
Unless they are corroded , the fuses are easy to spot if burned. The lid or manual should list fuses -size -and location fine a bright light to inspect them with.
If you don't hear a click ,its the fuse / relay /or wire to the starter . Since it just died my guess is the fuse.
Sorry I didn't reply quicker , I did the Xmas eve down at Moms house .
Anyone ever done front brake pads/rotors on 1993 300E/W124? Tips before I start? marshamk W124 E,CE,D,TD Class 2 05-31-2007 09:23 PM
Asr 1993 600sl akelboyz R129 SL Class 5 01-05-2007 03:21 PM
1993 300E 2.8 No Start after opening Relay Box mblink W124 E,CE,D,TD Class 10 11-07-2006 05:44 AM
1993 600 sl asr light peter hamlett R129 SL Class 1 09-10-2003 11:23 PM
1993 600 sl asr light peter hamlett R129 SL Class 0 08-06-2003 08:13 AM
