» Site Navigation
» Other Sites
Old 12-24-2007, 09:57 AM   #1 (permalink)
Date registered: Dec 2007
Vehicle: 1991 300D
Send a message via AIM to MP4-23
New to the forum and have a leaking 300D
The car is a 1990 300D, 136,000mi and it has been sitting in my garage for a year. I am going to start driving it again as soon as i get it registered. my mom took the car to a local mom n' pop garage and they told her that the Injection pump was leaking and that it had to be replaced. I found that hard to believe, because usually when there is a leak it is caused by a faulty gasket or seal. The leak is on top of the injection pump where the front hard line enters the IP. Can i replace all the seals on the lines at the IP? can i purchase these seals at a MB dealership? any special tools needed?
Any help/info would be great,
THANKS
MP4-23 is offline   Reply With Quote
Old 12-24-2007, 12:58 PM   #2 (permalink)
Date registered: Jan 2004
Vehicle: 190D 2.5 w120 sold
leaking 300D
Hi, agree with you. Doubt very much that you need a knew IP. If the fuel is coming out at the bottom of the injectors you have to install new o-rings and copper washers. You require a special socket to remove the part directly situated on top of the pump. You have to be very careful not to disturb the valve parts in the pump. A garage should charge only a couple of hours to change the o-rings. Also make sure the hard fuel lines have all the plastic clips to hold the lines in place. Othewise the lines will break at the ends due to metal fatigue. Good luck
QUOTE=MP4-23;2672252]The car is a 1990 300D, 136,000mi and it has been sitting in my garage for a year. I am going to start driving it again as soon as i get it registered. my mom took the car to a local mom n' pop garage and they told her that the Injection pump was leaking and that it had to be replaced. I found that hard to believe, because usually when there is a leak it is caused by a faulty gasket or seal. The leak is on top of the injection pump where the front hard line enters the IP. Can i replace all the seals on the lines at the IP? can i purchase these seals at a MB dealership? any special tools needed?
THANKS[/quote]
Wianka@000 is offline   Reply With Quote
coolant leaking..shows NO signs of leaking on hoses cangolden W124 E,CE,D,TD Class 9 09-10-2005 12:38 PM
Posted in wrong forum.. Need to sell my 83 300D Turbo :( AdvisorGuy W123 E,CE,D,CD,TD,TE Class 0 12-05-2003 08:02 AM
Just noticed that there is a forum for the C32. I do enjoy all the SLK's in the same forum, but... Marc32 R170 SLK Class 19 02-22-2002 06:35 PM
advice wanted - leaking tranny 300D Guest (MBNZ) W124 E,CE,D,TD Class 2 02-14-2002 06:52 AM
im sick of my leaking 300d Guest (MBNZ) W123 E,CE,D,CD,TD,TE Class 0 01-07-2002 02:38 AM
