» Site Navigation
» Other Sites
Old 12-22-2007, 02:50 PM   #1 (permalink)
Date registered: Nov 2007
Vehicle: W124-300E model 1987
Thumbs up Fix Engine Hesitation
Hi Benz World
Finally my car become ok, because recently I suffer form engine hesitation. After seek I fond the problem is air leak in the engine intake manifold, leak in the seals of the injectors ( I show u the seals in attached image ). I fond the problem by spraying fuel to the seal of injectors while engine idle, I note the hesitation increase. After replacing the seals with new the engine become ok.
s350thebest is offline   Reply With Quote
Old 12-23-2007, 01:54 AM   #2 (permalink)
neanderthal's Avatar
Date registered: Dec 2003
glad you found it. diagnosing those can be a beast
'O=00=O' BMW 2002. long live the legend.
neanderthal is offline   Reply With Quote
Old 12-25-2007, 05:53 AM   #3 (permalink)
samm's Avatar
Date registered: Jan 2004
Vehicle: Mercedes S320 1995
Thumbs up
That gives me a little food for thought....
I have a slight hesiation sometimes and Ive already changed all the valve stem seals due to oil leaking onto the injectors. I have been told by quite a few of the mature Merc mechanics that the 300e almost always had leaks in the intake gaskets and injector seals.
I was told to test it with water. If there is a leak then the water would be taken into the engine and an immediate hesitation would result. Excellent I will check it out!
Thanks s350
samm is offline   Reply With Quote
Old 12-25-2007, 06:20 AM   #4 (permalink)
Date registered: May 2003
Vehicle: E320 wagon
I replaced mine at 100 K miles ,they caused a surge under 1000 rpm . The plastic ring groves can chip or crack while replacing these .As long as they seal on the inner and out surfaces its fine .I seems the complete set of seals were 5-$10 U.S.
Uboater is offline   Reply With Quote
Engine Hesitation Adoni G-Class 7 05-14-2006 12:33 PM
engine hesitation majorkahuna W163 M-Class 22 12-16-2005 01:27 AM
ML Engine Hesitation Problem (again) aco_coa W163 M-Class 6 06-12-2004 02:38 PM
UPDATE! ML still at the dealer for hesitation problem fix, working with lemon law attorneys! djdragan W163 M-Class 4 12-26-2003 10:47 PM
is there any way to fix the hesitation problem kermalou R170 SLK Class 11 04-17-2002 05:22 PM
