Old 12-16-2007, 10:23 PM   #1 (permalink)
Date registered: Oct 2007
Vehicle: 1991 300 CE 24 Valve
Help Please !!!! 300CE 24 Valve dead
Hi Everyone,
Sorry for my first post to be a request but it appears I have a major problem.
I have recently bought a 300CE 24 Valave 1991 model in anthracite and as i was enjoying the car it decided to just go dead. All the electrics work and the car will turn over it just won't fire up.
I have had a mechanic look at it after having it towed home and he has disclossed to me that it is the Idle control module witch apparently runs the electronic part of the fuel injection. He has quoted me $6500 in Aussie dollars for the is part. Which I know is way overpriced.
My questions are:
Does anyone have the part number for this part. I cannot seem to find the MB part number for this?
Has anyone else experienced this problem? Was it this part?
Any assistance would be greatly appreciated.
MB300CE24 is offline   Reply With Quote
Old 12-16-2007, 10:41 PM   #2 (permalink)
BenzWorld W126 & W201 Host
spanners's Avatar
Date registered: Feb 2003
Vehicle: 1988 420SE, 2002 C180 Kompressor, 200 ML320
Send a message via MSN to spanners
More likely to be the fuel pump relay. Very common fault.
Work is the curse of the drinking class!
spanners is offline   Reply With Quote
Old 12-17-2007, 01:39 PM   #3 (permalink)
Hi Thanks for the reply,
How ever this is not the case. The engine has absolutely no spark coming from the leads.
The distributer, the coil etc have all been checked as well as the cam and knock sensor.
Please can someone help me with the part number for an ignition control sensor.
I have looked at all the numbers on the part and none correspond.
Many thanks
Old 12-17-2007, 03:09 PM   #4 (permalink)
Date registered: Jul 2004
Ignition control module(EZL) or idle control valve? A price like that, if the exchange rate is what I think it is, would have to be the EZL, which indeed are prone to failure in your car. Even then the price is ridiculous. There are several EZL rebuilders in the U.S. In any case you should subscribe to EPC, which is either $3 a month or free, not sure now, and find out exactly what part your car has. Could be a different setup than the U.S. If possible it's nice to be able to swap out the EZL with another car to make sure that's the problem. Here are some hopefully helpful links.
Idle Control Valve:
Your Parts Search Returned 1 Part(s)
EZL Rebuilder:
Mercedes Benz Accessories
MB Electronic Parts Catalog:
EPC online
deanyel is offline   Reply With Quote
Old 12-17-2007, 08:23 PM   #5 (permalink)
neanderthal's Avatar
Date registered: Dec 2003
on the early M104s, the ignitino coils can go out and are very expensive. different design for later models.
'O=00=O' BMW 2002. long live the legend.
neanderthal is offline   Reply With Quote
Old 12-17-2007, 08:56 PM   #6 (permalink)
Early 104 motors, i.e. the pre-HFMs, have only a single ignition coil, which is rather inexpensive ($70-$80) and not particularly prone to failure. These cars still had distributor caps and rotors. I believe the issue here is the ignition control module or EZL which is something else entirely - but some clarification would be helpful.
Old 12-17-2007, 09:11 PM   #7 (permalink)
Hi Guys,
Thanks so much for your replies. It is indeed the Ignition Control Box I believe it is called.
Part number
A 012 545 21 32 or A 012 545 20 32
There seems to be different prices despite it being the same part (funny I know) Spoke to an actual very nice guy at a dealer believe it or not.
The prices are $4572 and $9032 Aussie dollars.
Have spoken to the dealer and the part can easily be used with one from the US as he has checked and it is the same part world wide.
He has advised to replace these parts first.
Distributor Cap and rotor
Cam angle sensor
Crank angle sensor
and the coil
Could any of you knowledgable guys tell me if this would be the correct way to go about things firstly?
Then if I need the part being the Ignition control box sourcing it from the states amy well be the way forward.
Unfortunately i do not know any one with one of these cars so this is about the only way I can go
Dead... Like Dead Dead..... I apologize. techno W123 E,CE,D,CD,TD,TE Class 5 01-18-2007 08:26 PM
300ce Sportline and 300Ce Difference ! StarGazer W124 E,CE,D,TD Class 12 01-05-2007 09:50 AM
Will the "Plumbing Valve" work with a 300CE (24v engine)? Erwin8r W124 E,CE,D,TD Class 0 09-08-2006 09:21 AM
Why is 300CE 12-valve so sluggish? Guest (MBNZ) W124 E,CE,D,TD Class 3 05-01-2001 09:48 AM
Fuel mixture setting in 1990 300CE-24 valve 104 Guest (MBNZ) W124 E,CE,D,TD Class 0 02-08-2001 08:04 AM
