» Site Navigation
» Other Sites
Old 12-16-2007, 04:17 PM   #1 (permalink)
Date registered: Nov 2007
oil pressure question. why does...
when i start the car, a '95 e320, the oil pressure gauge goes up and then quickly comes back down to zero and stays there. i shut the car off and try it again and the same thing happens. does this mean that the oil pump is bad or the oil sending unit(oil pressure sensor)? thanks.
chimpum-callao is offline   Reply With Quote
Old 12-16-2007, 04:57 PM   #2 (permalink)
Jayare's Avatar
Date registered: Jun 2005
Vehicle: 90 300CE, 92 300E (sold), 93 400E, 02 Olds Aurora
Sounds like you have a faulty sending unit. I would get it check/replaced right away.. How long has this been going on?
Good Luck,
Jayare
Jayare is online now   Reply With Quote
Old 12-16-2007, 07:02 PM   #3 (permalink)
where is it located? the car has been sitting for quite a while and i just noticed it when starting it up, but do not keep the car running.
Old 12-16-2007, 08:44 PM   #4 (permalink)
Jayare's Avatar
It should be at the base of the oil filter block (what the filter attaches to) It will be a bit smaller than a tennis ball in diameter and have a single wire attached.
Good Luck,
Jayare
Old 12-17-2007, 12:33 AM   #5 (permalink)
augapfel's Avatar
Date registered: Jan 2006
Vehicle: 88 260E, 88 300E x 2, 88 300TE x 2
The sender unscrews from the oil filter base. Don't lose/forget the aluminum washer that goes between the sender and the base.
augapfel is offline   Reply With Quote
Old 12-17-2007, 05:50 PM   #6 (permalink)
Date registered: Jul 2007
Vehicle: 1994 E320 Dragon Wagon
Your valve train would sound clattery, loud ticking if you had no oil pressure.
Not saying you should roar around in your car but your ear should tell you clearly if there is total loss of oil pressure. With the hood is up and the car running it should sound normal. If any excessive noise is detected - shut her down.
Anything Made can be Made Better
White_Knuckles is offline   Reply With Quote
Old 12-17-2007, 09:11 PM   #7 (permalink)
any easy way to get to it? i see that the intake is in the way or am i looking at it all wrong? thanks for your help folks.
Old 12-18-2007, 12:26 AM   #8 (permalink)
Vehicle: 89' 260E
Did mine from the bottom end of the car.. Try putting it up on jack stands and from there you'll pretty much have free space to access it..
drin is offline   Reply With Quote
Old 12-18-2007, 07:16 AM   #9 (permalink)
Date registered: Jul 2004
Clearly bottom of the car, not really necessary to drain the oil but if you have an oil change coming out might as well do it then.
deanyel is offline   Reply With Quote
Oil Pressure Question?? FRED 524 W124 E,CE,D,TD Class 8 11-16-2006 07:51 AM
Oil Pressure Question AstroSilver W123 E,CE,D,CD,TD,TE Class 2 10-02-2005 01:47 PM
Oil pressure question rsc52 W123 E,CE,D,CD,TD,TE Class 5 09-18-2005 10:19 AM
Oil Pressure question redzer007 W124 E,CE,D,TD Class 1 03-22-2005 03:12 AM
oil pressure question 96S320. W140 S-Class 8 08-10-2004 02:04 PM
