» Site Navigation
» Other Sites
Old 12-15-2007, 05:06 PM   #1 (permalink)
Date registered: Aug 2007
CV Joint Cover Separation
How (and where) does the cover separate on the outer CV joint?
I need to get this apart, clean, and re-lube pronto.
The inner was a piece of cake, put together the same way as a VW.
I can't seem to find the joint on the outer where the cover splits.
TIA
1987 300D Turbo
180k (I think)
Duncwarw is offline   Reply With Quote
Old 12-15-2007, 06:42 PM   #2 (permalink)
augapfel's Avatar
Date registered: Jan 2006
Vehicle: 88 260E, 88 300E x 2, 88 300TE x 2
Sorry Charlie! No can do. The outer CV joint has that swaged-on metal reducer and then the boot clamps to that (and the axle shaft). AFAIK you have to cut the clamps to pull the boot back and clean/regrease the outer joint.
augapfel is online now   Reply With Quote
Old 12-15-2007, 07:54 PM   #3 (permalink)
Ah. That might explain why it didn't succumb to my loving touch.
Thanks. Now I know.
Old 12-18-2007, 03:48 PM   #4 (permalink)
Date registered: Nov 2007
Vehicle: 2000 E320 4matic
My right, outer CV Joint is making noise when wheel is fully turned.
consulted 2 independent mechanics - as well reserach on-line - and the only option is to replace the entire axle ($1100). One mechanic recommended checking back with him in 6 months to see if individual part becomes available.
any advice regarding urgency to replace this? experience with other parts not being available or only through dealer and time for part to eventually come out?
cksvensk is offline   Reply With Quote
Old 12-19-2007, 04:54 AM   #5 (permalink)
augapfel's Avatar
Your car is not the W124 chassis. I think it's a W210. Those forum members are better suited to answer your question. I was about to say that I'm sure that rebuilt axles are available for your application but then I saw that it is a 4matic. And you haven't said whether the front or rear axle is noisy...
Separation of Church and State: Somebody had it Right in 1802 94Wagenmeister Off-Topic 136 07-05-2007 06:43 PM
CV JOINT Benzy89 W124 E,CE,D,TD Class 0 07-02-2007 06:50 PM
inner cv joint shaney V-Class 6 05-08-2007 04:57 PM
separation of church and state is "a lie" drewprof Off-Topic 34 08-29-2006 02:58 PM
A new take on the door panel separation.... JSF - South Jersey R170 SLK Class 5 08-16-2001 05:23 PM
