Old 12-13-2007, 08:44 AM   #1 (permalink)
Date registered: Dec 2007
How to replace headlight switch micro bulb ??
All,
1994 E320 bulb burned out in switch, how do I get to this $%^&*?
TIA
2OHtwo
2OHtwo
1972 BMW 2002 0(lll)(lll)0
1994 E320w
2OHTWO is offline   Reply With Quote
Old 12-13-2007, 06:18 PM   #2 (permalink)
Date registered: Jul 2007
Vehicle: 1994 E320 Dragon Wagon
The knob pulls off (firm grip) then there's a nut holding the switch assembly on the panel. The trim section then pulls out. You'll find the back light on a two wire harness. I couldn't pull my bulb out, may have been melted into the socket.
If you're talking about the fog lamp indicator that's on the switch assy. you'll see it when the knob pulls off. If you get a part number for the lamp - post it the dealer couldn't find one for mine as well the shift selection lamp in the console has no part number.
I am going to find a different source for these bulbs as someone must make a low wattage 12V micro bulb.
Anything Made can be Made Better
White_Knuckles is offline   Reply With Quote
Old 12-13-2007, 06:35 PM   #3 (permalink)
sarasotajoe's Avatar
Vehicle: 1992 300D 2.5 Turbo - The White Falcon
I can get those bulbs cheap for you guys, pm me...could you get the knob off?
p.s. i can get the shift selector bulb too ;-o
Mit Frendlichen Grüßen,
Sarasota Joe
sarasotajoe is offline   Reply With Quote
Old 12-14-2007, 05:22 PM   #4 (permalink)
You can find the bulbs eh? Part numbers or source would be cool. The local dealer and a couple regional calls yielded nothing for me. They acted like I was annoying them to look up a cheap sale.
The knob pulls straight off with strong pulling force.
Old 12-15-2007, 04:10 AM   #5 (permalink)
sdjohanson's Avatar
Thanks for the bulbs Joe!
sdjohanson is offline   Reply With Quote
Old 12-19-2007, 04:55 AM   #6 (permalink)
Done -and thanks!
Thanks to the help, the new bulb is in! About ten minutes and five of that was cleaning behind the panel!
Micro switch/relays again H-TOWN230 R170 SLK Class 32 12-05-2006 01:48 PM
How to replace a little headlight bulb? okiloveu W210 E-Class 5 11-24-2006 12:09 AM
How to replace headlight bulb msmmgr R170 SLK Class 2 10-11-2006 06:24 AM
how to replace bulb in headlight switch mr diesel W123 E,CE,D,CD,TD,TE Class 2 09-12-2006 08:26 PM
NEW USER > HOW TO REPLACE THE BULB in DRIVER SIDE FRONT HEADLIGHT?? yak W220 S-Class 0 03-21-2006 08:22 AM
