» Site Navigation
» Other Sites
Old 12-04-2007, 08:45 PM   #1 (permalink)
Date registered: Nov 2007
no oil pressure. could the oil pump be the only problem?
it's on a '95 E320. when i start the car, i get no oil pressure reading from the gauge. at times it may climb close to the 1 but then drops quickly and stays down the whole time. like my question says, is the oil pump the only thing i should worry about? what else should i look for? thanks.
chimpum-callao is offline   Reply With Quote
Old 12-04-2007, 08:48 PM   #2 (permalink)
neanderthal's Avatar
Date registered: Dec 2003
get a new oil pressure sensor stat.
the oil pressure is the most important reading of the engine. more than engine temperature. if you drive the car with low oil pressure you run the risk of hearing expensive noises.
caveat emptor
'O=00=O' BMW 2002. long live the legend.
neanderthal is offline   Reply With Quote
Old 12-04-2007, 09:10 PM   #3 (permalink)
caveat emptor
i will try this first. i dont know why i did'nt think of this before. i'll let you know what happens in a few days after i try this. thanks.
i hope its the oil pressure sensor not the pump!!!! b u r t W126 S,SE,SEC,SEL,SD,SDL Class 7 12-19-2005 11:59 AM
Oil pressure problem s600 W123 E,CE,D,CD,TD,TE Class 10 10-30-2005 03:13 PM
oil pressure problem haridevm W201 190E, D-Class 12 12-30-2004 04:32 AM
oil pressure/oil pump ...ronin W124 E,CE,D,TD Class 3 01-16-2004 03:27 PM
Oil Pressure problem 190E-Boy W201 190E, D-Class 2 02-06-2003 02:38 PM
