» Site Navigation
» Other Sites
Old 12-03-2007, 11:25 AM   #1 (permalink)
swanny2070's Avatar
Date registered: Aug 2006
Vehicle: 1994 e320 Cabriolet
Replacing the Coils, Plugs, wires, etc. 1994 e320 cabrio
Howdy,
It this a difficult job? It seems straightforward, pop the cover off and get to work. Do the plugs need to be under a certain torque, or just barely tighten them. I would hate to strip the plug threads, as this is what happened with another car with an aluminum engine. I think the e320 has a steel engine, correct? I also saw non-Bosch aftermarket coils for about $60 USD online, or should one pay for the more expensive Bosch parts? Any help would be appreciated...
-Dan
swanny2070 is offline   Reply With Quote
Old 12-03-2007, 11:54 AM   #2 (permalink)
94Wagenmeister's Avatar
Date registered: May 2005
Send a message via AIM to 94Wagenmeister
Any reason to replace the coils? It's not my experience that they (hardly) ever fail on the 104 engine. If you do ALWAYS stay with Bosch or OEM.
"There is nothing moe expensive than a cheap Mercedes"
"There is nothing more apt to fail than aftermarket parts on a Mercedes"
Scott in MD/DC
94 E320 Wagon (Just getting broken in)
95 C280 (RIP)
87 190E (Sold)
"There is nothing more expensive than a cheap Mercedes"
94Wagenmeister is online now   Reply With Quote
Old 12-03-2007, 12:10 PM   #3 (permalink)
Date registered: Jul 2004
No, not a difficult job. If your wiring harness is original expect to replace that too - moving it out of the way will very likely ruin it. You may strip out a bolt or two on the spark plug cover - very common, fixed with helicoils or not fixed at all. Your engine is alloy head and cast iron block. Bosch coils should be less than $60 - I'd stick with those.
deanyel is offline   Reply With Quote
Old 12-03-2007, 12:12 PM   #4 (permalink)
vili1982's Avatar
Date registered: Jan 2005
Vehicle: 95 E320 Coupe, Diesel Golf
Send a message via MSN to vili1982
it's a pretty straight forward job, tighted the plugs to a point where you are not sweating. And the guy on top is right coils rearly ever go on 104's dont replace them if everything is fine, also make sure to get the correct firing order once yot put everything back in.
good luck
In the world of roads, there are those who travel and those who own it. The choice is yours.
95 Coupe
vili1982 is offline   Reply With Quote
Old 12-03-2007, 12:13 PM   #5 (permalink)
Date registered: Dec 2006
Vehicle: 1997 E320, 1997 S320
just change the 3 spark plug connectors (Beru) and spark plugs (F8DC4 - Bosch). pretty easy straightforward job.
tirona is offline   Reply With Quote
Replacing Cabin Filters on 1994-1995 e320 michaelscoots W124 E,CE,D,TD Class 15 08-03-2007 02:52 AM
Flickering console lights 1994 e320 Cabrio swanny2070 W124 E,CE,D,TD Class 1 11-16-2006 12:06 AM
1994 e320 Cabrio Interior Parts swanny2070 W124 E,CE,D,TD Class 2 11-15-2006 09:41 PM
spark plug wires/coils en-em W163 M-Class 4 07-27-2006 01:48 AM
Engine knocks after replacing plugs and wires Heav-e-d W201 190E, D-Class 7 05-29-2006 10:08 AM
