Old 11-28-2007, 10:48 AM   #1 (permalink)
Date registered: Feb 2007
Will these rims fit?
I have a 95 E320 wagon and was looking at the 17 AMG rims in this ad:
http://www.benzworld.org/forums/sale...ls-sale-2.html
I was wondering if they would fit without any mods. I think the front would be fine. My concern would be about the rear. Are 17 X 8.5 too big for the rear? Thanks for your help.
airbenz is offline   Reply With Quote
Old 11-28-2007, 02:06 PM   #2 (permalink)
Date registered: Feb 2005
Vehicle: 1995 Mercedes-Benz E420 Special Edition
Send a message via AIM to chrisdpham Send a message via Yahoo to chrisdpham
What's the offset?
The rears will be fine - I have 8.5 in the rear of my W124.
chrisdpham is offline   Reply With Quote
Old 11-28-2007, 06:36 PM   #3 (permalink)
Mgr., Marg. Mead Taproom
mcbear's Avatar
Date registered: Apr 2004
Vehicle: 500Es
Send a message via AIM to mcbear
The ET [offset] should be around 34. I think those are right in that range so you will have no problem. Go to tirerack.com and get the exact tire size for your car and 17s. Don't go different as THAT would hinder a good fit.
Also, I would not suggest above 17" for a 124, they just don't play as well in the long run. 17" works fine, however.
McBear, Kentucky
| ------ 93 500E ---- | ---- 93 500E ---- | ---- 92 500E ---- | ---- 88 560SEC AMG ------|
| --- 2006 E500 --- | --- 92 300E Sportline --- | --- 80 280SL --- | --- 68 280SE Coupe --- |
http://mcallisterbryant.deviantart.com/
If they can get you asking the wrong questions, they don't have to worry about answers.
mcbear is offline   Reply With Quote
Old 11-28-2007, 08:07 PM   #4 (permalink)
Thanks for the replies, I believe the offset for the rear is 30mm, the rim size is 17 X 8.5. I am just worried about rubbing.
Will these rims fit? MB7882 W202 C-Class 7 07-20-2007 06:28 AM
what rims fit my E DEEZY W124 E,CE,D,TD Class 7 03-19-2006 07:50 PM
Will these rims fit? Studrat R170 SLK Class 4 03-16-2004 08:58 AM
will rims fit? Guest (MBNZ) W124 E,CE,D,TD Class 1 05-27-2002 03:47 PM
WILL RIMS THAT FIT W140 FIT A W126 BODY STYLE Guest (MBNZ) The Discount Tire Direct Tire, Wheel, Brake & Suspension 0 03-09-2002 05:25 PM
