» Site Navigation
» Other Sites
Old 11-26-2007, 02:57 PM   #1 (permalink)
The Melmaan's Avatar
Date registered: Sep 2006
Neutral Safety Switch R & R
Is there any one out there has found a better way of removing and replacing the Neutral Safety Switch?
What I did before was to remove the bolts from the flex disk and the engine mounting bolts, raise the engine so the tranny goes down to expose the switch - on the 190E.
I don't know if this will work with the 300E.
The Melmaan is online now   Reply With Quote
Old 11-26-2007, 06:16 PM   #2 (permalink)
Date registered: Jul 2004
You're supposed to be able to get it without dropping anything, but it is tight, helps to have small hands and quarter drive sockets.
deanyel is offline   Reply With Quote
Old 11-26-2007, 09:11 PM   #3 (permalink)
R & R
I know it is so cramped in there. Sweat it is then sweat it is.
Is it 10mm on qtr driver, the way I look at it, the thing that will give me problems is the wiring connector. It seems to be stuck in there real tight.
Old 11-27-2007, 05:25 AM   #4 (permalink)
Sergio's Avatar
Date registered: Sep 2002
Vehicle: 1995 E320
The wiring connector has a locking mechanism. Twist the white ring clockwise to unlock and then use a flat blade screwdriver to pop the connector off. It should be easy. Don't raise the engine, just fit a 10mm socket into the 2 bolts, loosen, and remove the switch.
Sergio
'95 E320 SE
'99 ML430 (gone)
'01 E320 Wagon 4-Matic
'94 C280 (R.I.P)
Sergio is offline   Reply With Quote
Old 11-27-2007, 08:54 AM   #5 (permalink)
Gracias Sergio...
Old 11-28-2007, 05:47 AM   #6 (permalink)
Sergio's Avatar
Vehicle: 1995 E320
De nada.
neutral safety switch NüR-SPEC W126 S,SE,SEC,SEL,SD,SDL Class 5 04-23-2007 08:01 PM
Neutral safety switch cbx79 W124 E,CE,D,TD Class 1 04-19-2006 01:01 PM
Neutral Safety Switch Chupper W124 E,CE,D,TD Class 1 01-11-2004 03:33 PM
neutral safety switch Guest (MBNZ) W123 E,CE,D,CD,TD,TE Class 1 06-27-2002 10:32 AM
neutral safety switch Guest (MBNZ) W123 E,CE,D,CD,TD,TE Class 1 09-05-2001 01:16 AM
