Old 11-16-2007, 05:50 AM   #1 (permalink)
Date registered: Apr 2006
Automatic Transmission
My W124, 90' 230E has problem on the automatic transmission when switch to reverse gear, there is a light griding sound when reverse ( there is friction on reverse ) but the car still in motion, when apply the brake in reverse gear, the griding sound is significant and there is a little vibration and the car still in a little bit motion. This case only happened when the engine is cold and the car is parked for few hours. When hot engine the car runs normal. Does anybody know what happen to my car and let me know how to fix it.
4484
4484 is offline   Reply With Quote
Old 11-16-2007, 07:22 AM   #2 (permalink)
jmoney6's Avatar
Date registered: Feb 2007
Vehicle: 300e 4Matic
have you or had someone change your automatic transmission fluid recently? if so did you.they use the correct viscosity oil?
jmoney6 is offline   Reply With Quote
Old 11-17-2007, 02:17 AM   #3 (permalink)
imoney6,
I had changed the benz automatic fluid by myself three years ago and has running 40000 Km for this three years togrther with the filter.
4484
Old 12-12-2007, 02:49 PM   #4 (permalink)
Date registered: Oct 2007
Did you ever find out anything about your transmission? Mine is doing something similar:
1. when I leave the house in the morning the car goes into reverse and works fine that way
2. after driving for a little while (15 - 30 minutes) it won't completely engage reverse
I had to, just a few minutes ago, open my driver side door and give the car a push with my left foot while gassing it with my right foot to get the car to go in reverse. It feels like it wants to engage reverse and the higher I rev the engine the more it sounds like it is trying. Not sure if that is vacuum or the loss of the reverse band.
I'm already looking for rebuilt transmission dealers.
billb95 is offline   Reply With Quote
Old 12-12-2007, 04:17 PM   #5 (permalink)
hamada128's Avatar
Date registered: Jan 2007
Vehicle: 93 190E 2.3
thats a sign of bad tranny.
1972 Fiat 128 1100cc
1993 MB 190E 2.3 255K
2008 Lancer 1300cc - Gulf Edition
MB Driver since 10/22/06
hamada128 is offline   Reply With Quote
Old 12-13-2007, 12:52 PM   #6 (permalink)
That's what I thought. I've already been searching for a used transmission to replace it.
Thanks.
1995 E320
Old 12-14-2007, 04:35 AM   #7 (permalink)
Date registered: May 2003
Vehicle: E320 wagon
There is a seal "piston" common problem ,B3 I think ?. With cold thick fluid it will shift the piston ,once the oil gets hot it bleeds past the seal never applying full pressure to the clutch plates .Some Lucas additives help depending how bad it is .
Plan you parking facing up hill or drive through spot facing out . I think a junk yard tranny is 600 - $800 .A rebuilt unit NO core return $1300 -$1500 depending on shipping.
Uboater is offline   Reply With Quote
Old 12-14-2007, 09:32 AM   #8 (permalink)
I saw that silver star transmissions had some rebuilts for that price range. The more I think about it I'd rather go that route than used. It doesn't seem worth it to ship the core back to them. From some posts I've seen they rarely find a transmission good enough to refund the $300 - $500 core return charge. But before I go that route I am going to try the Lucas transmission additive. Thanks for the input.
Automatic Transmission garibs W126 S,SE,SEC,SEL,SD,SDL Class 1 11-13-2006 02:22 PM
automatic transmission 428 lily G-Class 2 08-22-2005 07:43 PM
Automatic transmission osoro General Mercedes-Benz 1 07-01-2004 04:23 AM
Automatic transmission question: anyone knows how to make the transmission shift at a higher RPM, DanPro1 R170 SLK Class 8 10-07-2002 02:35 PM
Prefacelift SLK: shift-knobs for automatic transmission can be installed on manual transmission? Marcello (Piacenza - R170 SLK Class 3 04-26-2002 11:05 AM
