Old 12-27-2007, 11:39 AM   #51 (permalink)
Mgr., Marg. Mead Taproom
mcbear's Avatar
Date registered: Apr 2004
Vehicle: 500Es
Send a message via AIM to mcbear
Originally Posted by Campo09 View Post
Actually K&N Air filters dont do anything for my car due to the Oxygen Sensor only at 75 % throttle is the sensor turned off and when the K&N air filter is put in the oxygen sensor re-adjusts. I already have 2 twin magnaflow (2.5 inch) which is said to increase horsepower but decrease torque.
The problem you are having with torque is due to the size of pipe used. If you decrease the overall diameter a bit and use the single Magnaflow Cat and muffler you will get the same HP increase but will get your low end torque back. What you are doing is reducing your backpressure too much which eliminates a bit of the draw from the engine. I would bet that your topend [up around 130ish] graphs better as that setup that you have would work better for a topend application rather than a low end torque app.
McBear, Kentucky
| ------ 93 500E ---- | ---- 93 500E ---- | ---- 92 500E ---- | ---- 88 560SEC AMG ------|
| --- 2006 E500 --- | --- 92 300E Sportline --- | --- 80 280SL --- | --- 68 280SE Coupe --- |
http://mcallisterbryant.deviantart.com/
If they can get you asking the wrong questions, they don't have to worry about answers.
mcbear is offline   Reply With Quote
Old 12-27-2007, 03:20 PM   #52 (permalink)
Campo09's Avatar
Date registered: Aug 2007
Vehicle: 1986 Mercedes-Benz 300e
Send a message via AIM to Campo09
ok thanks for your help
Campo09 is offline   Reply With Quote
Old 01-07-2008, 08:59 PM   #53 (permalink)
cascade's Avatar
Date registered: Nov 2006
Vehicle: 1991 AMG 560SEC, 130k (Pearl black/black); 2008 Subaru Outback PZEV, 6,700 (actual) miles.
W126 420 engine/trans into W124 - will it fit?
Friend of mine has a W124 and the engine is dying. Rather than rebuild it, he's found a wrecked W126 420SEL with a good engine and transmission.
Could the 420SEL engine and tranny drop into the W124 wagon? Would they even fit? Is the driveshaft the same? What about the electronics and wiring harness? Could he leve the rear end of the 300TE in place?
Any other probems? Would this even be cost effective?
"I swear to god, it's like I live in a trailer of common sense, and stare out the window at a tornado of stupidity."
"Rule for Life: You need only two tools: WD-40 and duct tape. If it doesn't move and it should, use WD-40. If it moves and it shouldn't, use the duct tape." -----------------------------------------------
Oil Burner Kartel Member #53
cascade is offline   Reply With Quote
Old 01-11-2008, 06:59 PM   #54 (permalink)
mcbear's Avatar
Vehicle: 500Es
Any other problems? Would this even be cost effective?
It is doable BUT it would require a bunch of harness work, computer work, a bit of inner fender work and maybe a bit more [for some reason I am thinking firewall]. If that is a 117 motor it is essentially a very detuned Hammer style motor application. In about two weeks Jono will be able to give you much clearer information on that fitment but I frankly would just get another M103/104 motor and put in. That can be done for Under $3K rebuilt. The other will require an open checkbook I fear.
Old 01-14-2008, 02:52 PM   #55 (permalink)
S.M. Autoworks's Avatar
Vehicle: '92 400CE, '83 500SEC, '98 S320
There once was a parts delivery driver that came here with a 560 motor in an 88 TE. It sounded sicko! I really didn't take a hard look at it, but I know it has been done.
At the moment, I am trying to clear the fog in my head, as to remember which yard he came from.
S.M. Autoworks is offline   Reply With Quote
Old 01-16-2008, 06:52 PM   #56 (permalink)
Date registered: Feb 2003
Vehicle: 360TE AMG; 500E
I successfully have a C36 power-train in my 1988 W124 wagon. It's now about 6-years old since the conversion.
If I had to do it over again, I would have sold the 1989 for a 1993-1995 wagon which had HFM from the start. The conversion would have been so much easier.
She's factory perfect, though, even with OBD-II, and a CARB sticker to prove it!
I'm contemplating a M119 into a W124 wagon or 400E/500E turned into W124 wagon.
Converse Engineering in Maine, did a Ford DOHC V8 into a 1988 W124 wagon as well, turnkey I believe is about $15K with car!
Also, I've seen a 1999 twin-turbo diesel into a 1993 S350, so I'm sure if you have a W124 diesel this swap can be done as well (he used the injection pump from the stock W124 diesel, and the existing tranny, so minimal computer work).
:-) neil
1988 E36T AMG ( SportLine 360TE AMG )
1993 500E
1995 E320 wagon
:-) neil
1988 360TE AMG
1993 500E
1995 E320 wagon
M104-AMG is offline   Reply With Quote
Old 01-16-2008, 06:58 PM   #57 (permalink)
Ford V8 into W124 wagon
From Converse Engineering:
This is a 1989 Mercedes 300 TE wagon that was recently completed. The original Mercedes straight 6 was replaced by a 1994 Lincoln Mark VIII 4.6L 32 valve engine and transmission. This is essentially the same motor found in the later Mustang Cobras. The engine is a perfect match for the Mercedes as it is incredibly smooth and free-revving.
Old 01-17-2008, 10:53 AM   #58 (permalink)
MiguelXJ's Avatar
Vehicle: '91 230CE; '93 220E Sportline
Holy Sh***!!!!
Glad to see a shop working so often with W124s
1991 230CE
1993 220E Sportline
1989 200TD - sold
MiguelXJ is offline   Reply With Quote
Old 01-20-2008, 05:15 AM   #59 (permalink)
xbnziv's Avatar
Date registered: Oct 2007
Vehicle: '86 300E
Hello there everyone,
Its so good to see everyone getting behind the wonderful W124 and seeing what they can make of it with a little commitment.
Me and a good friend have been throwing ideas around for something a little different here in Queensland (AUS) of late and I was seeing if anyone has seen/heard of a 1UZ-FE (toyota/lexus 4.0L quad cam) conversion? I have heard of toyota 2JZ - GTE twin turbo conversions done in singapore and thailand, (not sure about AUS) but nothing on the 4.0L Quad cam front...
Anything on this matter, opinions or otherwise on either the 1UZ, 1JZ-GTE or 2JZ-GTE would be greatly appreciated.
B3NZ'D - 4 - L!F3
xbnziv is offline   Reply With Quote
Old 01-29-2008, 07:13 PM   #60 (permalink)
Vehicle: 1992 400E
i just bought a 92 400E and all i can say is WOW!!! 275 hp in the lap of luxury!!!! Anyway after several burnouts and 120mph runs on the freeway im outa fuel. what octane does this 400E run on?
camvaugeois is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
micropone
W124 E Class Picture Thread... salamanca W124 E,CE,D,TD Class 815 Yesterday 10:31 PM
Do It Yourself (DIY) repair thread W124/300E GHM W124 E,CE,D,TD Class 1 11-11-2005 08:57 AM
pic thread W124 . continue sagamol W124 E,CE,D,TD Class 3 07-12-2005 06:47 AM
what's up with the W124 pictures thread CEorbust W124 E,CE,D,TD Class 1 12-30-2004 11:26 AM
Whats up with the W124 picture thread? Nagchampa W124 E,CE,D,TD Class 3 11-28-2004 12:58 PM
